Add a little dab of different colors to differentiate them like 1:1.
Italari 1/12 Renault RE20 Turbo
More done to this (I'm really enjoying this)
[ATTACH]429077[/ATTACH]
[ATTACH]429078[/ATTACH]
[ATTACH]429079[/ATTACH]
[ATTACH]429080[/ATTACH]
[ATTACH]429081[/ATTACH]
[ATTACH]429082[/ATTACH]
[ATTACH]429083[/ATTACH]Comment
Guest -
More work on the RE20 the ht leads are very soft rubber tubing onto which you are supposed to push these very hard vinyl plug caps, totally impossible so my answer get some copper wire file the end down so the rubber tube fits in then push the vinyl caps on the wire (at the thicker end) then slide the cap onto the tube.
[ATTACH]429250[/ATTACH]
[ATTACH]429251[/ATTACH]
[ATTACH]429252[/ATTACH]
[ATTACH]429253[/ATTACH]
[ATTACH]429254[/ATTACH]
[ATTACH]429255[/ATTACH]
[ATTACH]429256[/ATTACH]
Those nuts on the suspension roots caused more than a few swear words what a pita (can't tell you how many times they ended up on the floor) a real trial of patience.
[ATTACH]429257[/ATTACH]
[ATTACH]429258[/ATTACH]Comment
OK so we all know yellow is a pita but as a lot of this is yellow I thought I would spray some of it (I have to say I'm really pleased with the outcome)
[ATTACH]429399[/ATTACH]
[ATTACH]429400[/ATTACH]
[ATTACH]429401[/ATTACH]
[ATTACH]429402[/ATTACH]
[ATTACH]429403[/ATTACH]
[ATTACH]429404[/ATTACH]
those brake disks were a bit of a disappointment fit wise the twin discs would not go together, ther is a shoulder the outer disk is supposed to slide over (it didnt) but a little work with a dermel (by hand not in the dremel)grinding disk persuaded it to fit.
[ATTACH]429405[/ATTACH]
[ATTACH]429406[/ATTACH]
[ATTACH]429407[/ATTACH]
[ATTACH]429408[/ATTACH]Comment
More progress on this.
[ATTACH]429591[/ATTACH]
[ATTACH]429592[/ATTACH]
[ATTACH]429593[/ATTACH]
[ATTACH]429594[/ATTACH]
[ATTACH]429595[/ATTACH]
[ATTACH]429596[/ATTACH]
[ATTACH]429597[/ATTACH]Comment
Ken apologies for missing so much of this fine build. One thing that stands out is those fuel lines , great weathering , they look so real.
Great build all round.Comment
OK first off (as with everything in this kit) either the locating holes are too small or the locating pins are too big either way on the rear suspension it is really important to drill parts 342L and 343L holes out with a 1.8 mill drill like this.
[ATTACH]429677[/ATTACH]
Or you will end up with the problem I had with getting it off without snapping the pin that it goes into off as it will not go fully home if you don't drill it out.
The pluming on this is a nightmare (I should have labeled all the pipes at the start of this build) I am constantly having to go backwards and forwards through the instructions to find which pipe goes where, lesson learned.
[ATTACH]429678[/ATTACH]
[ATTACH]429679[/ATTACH]
[ATTACH]429680[/ATTACH]
[ATTACH]429681[/ATTACH]
[ATTACH]429682[/ATTACH]Comment
More done on this and a start on some masking.
[ATTACH]429711[/ATTACH]
[ATTACH]429712[/ATTACH]
[ATTACH]429713[/ATTACH]
[ATTACH]429714[/ATTACH]
[ATTACH]429715[/ATTACH]
[ATTACH]429716[/ATTACH]
[ATTACH]429717[/ATTACH]
[ATTACH]429718[/ATTACH]
[ATTACH]429719[/ATTACH]Comment
Hi all the instructions tell you to leave 2.5 mm of the stud sticking out of the hub and thread the wheel nut onto that unfortunately the narrow part of the hole into which you are supposed the thread the studvont is recessed 3 mill into the nut, my initial thought was to sand 3 mm off the nut thus bringing the thread able area forward, however the nut is tapered (as is the centre of the wheel) in the end I decided to drill the nut out so the hole was the same all the way through then drill that out 1.4 mm and thread that onto the stub, worked a treat.
[ATTACH]429760[/ATTACH]
[ATTACH]429761[/ATTACH]
[ATTACH]429762[/ATTACH]
[ATTACH]429763[/ATTACH]
[ATTACH]429764[/ATTACH]
[ATTACH]429765[/ATTACH]
[ATTACH]429766[/ATTACH]
[ATTACH]429767[/ATTACH]
[ATTACH]429768[/ATTACH]
[ATTACH]429769[/ATTACH]
The skirts are just placed there for a look see as there is loads more to do before they are finally fitted.
I'm really pleased with how this is going, I wonder if protar did any more of these F1 kits and if they can still be had on ebay and such.Comment
More work on this she now has all her wheels, one of the many really cool details of this kit is they even went to the trouble of molding the wear indicators on the tyres.
[ATTACH]429932[/ATTACH]
[ATTACH]429933[/ATTACH]
[ATTACH]429934[/ATTACH]
[ATTACH]429935[/ATTACH]
[ATTACH]429936[/ATTACH]
[ATTACH]429937[/ATTACH]
[ATTACH]429938[/ATTACH]
[ATTACH]429939[/ATTACH]
[ATTACH]429940[/ATTACH]Comment
Some of the exhaust and turbo parts primed, and the worst decal applied I'm not going to say that was hard but it did involve quite a few expletives and quite a bit of nail biting (they needed cutting anyway)
[ATTACH]430001[/ATTACH]
[ATTACH]430002[/ATTACH]
[ATTACH]430003[/ATTACH]
[ATTACH]430004[/ATTACH]
[ATTACH]430005[/ATTACH]Comment
