Revell 1/25 1970 Dodge Charger
  • Mr Bowcat
    SMF Supporter
    • Dec 2016
    • 4691
    • Bob
    • London
    Hi all,
    So, next on the bench is this.
    My eldest daughter is a fan of the films, and the Charger in particular. She is off to University in September to train to become a Midwife, and I wanted to build something for her to take with her as a little reminder of home.
    Si vis pacem, para bellum.
    • 16157
    No Dukes of Hazzard stripes then!
    • Mr Bowcat
      SMF Supporter
      • Dec 2016
      • 4691
      • Bob
      • London
      Not on a 1970 Charger Jim, that would be a '69.
      :tears-of-joy:
      Might have to do a DoH Charger though, loved that show as a kid.
      • Mr Bowcat
        SMF Supporter
        • Dec 2016
        • 4691
        • Bob
        • London
        Morning all.
        Made a start on this yesterday by getting the body prepped for paint. There was a bit of a seam along the front and rear wings, nothing too major. However the inside of the roof was terrible, four really deep EPM's, which as they had got in at an angle were raised on one side and low on the other. I got these filled and sanded, somewhat awkward due to the position and curves.
        The kit also comes with moulded trim on the wheel arches, however the F&F car does not have these, so a bit of slicing and sanding soon fixed that.
          I remember the one in Bullet that wrote off Steve McQueens Shelby Mustang... He was only meant to slide along the dirt, not go into the ditch.
            • 16157
            The head lining and the wheel arches look very neatly done. Much more care needed on a gloss finish than on some muddy old tank :smiling:
            • Mr Bowcat
              SMF Supporter
              • Dec 2016
              • 4691
              • Bob
              • London
              Morning gang.
              I realised I've not updated this thread, to engrossed in the build.
              The body has been painted and glossed, still needs flatting, polishing and the chrome trim painting, so will post pics of that when it's done.
              In the meantime I've pushed on with some other parts. First up, the engine.
              I used a Scale Production distributor which is now mostly hidden, but I think the leads look good. And yes, I'm that sad that the plugs are wired in the correct firing order.
              Also completed the interior. Now this wouldn't be a F&F car without a little Nitrous.
              I've now moved on to prepping the chassis and running gear and will update when that's done.
              • Stefee
                • Feb 2023
                • 1000
                • Stefan
                • Hemel Hempstead
                Love the detail on the engine and the alternator looks magnificent.
                • Andy T
                  • Apr 2021
                  • 3239
                  Stunning!
                  • yak face
                    • Jun 2009
                    • 14236
                    • Tony
                    Engine looks magnificent bob , looking forward to seeing the body , cheers tony
                    • Mr Bowcat
                      SMF Supporter
                      • Dec 2016
                      • 4691
                      • Bob
                      • London
                      Cheers guys.
                      • Mr Bowcat
                        SMF Supporter
                        • Dec 2016
                        • 4691
                        • Bob
                        • London
                        Morning all.
                        Well I've been having a nightmare with this. The body had been painted, glossed and polished some time ago but I still had to paint the chrome window trim. I masked everything up, and then in a stupid moment decided to use a paint pen for the chrome instead of airbrushing. This went disastrously with the chrome paint bleeding under the masking tape.
                        I tried to remove it with thinners and sanding, but of course this just made things worse. Luckily I had only done one side so decided just to respray the top of the door and edge of the roof that were damaged, so masked up this area. This left a paint ridge along the roof which I thought I could sand out. I was wrong, leading to more masking and the entire roof needing to be sprayed, glossed and polished again. Having done this I found some dust stuck in the boot (trunk) lid, and while trying to polish this out I got to close too the edge of the rear wing (which is very square) and rubbed through to primer. This then had to be sprayed again, which I did without masking to avoid the same issues I had with the roof.
                        So 3 weeks later I was back to square one and ready to paint the chrome trim again. I masked up again and did what I should of in the first place and airbrushed.
                        I still need to polish the body again but will wait a few days to make sure the chrome is fully cured. I really don't want to have to mask it all up again.
                        So lesson learned, don't try and cut corners.
                        • Tworrs
                          • Jan 2022
                          • 1982
                          • Garry
                          • New Zealand
                          Bob, I think that's called a comedy of errors, I'm glad you managed to save it though, she's looking good now.
                          • Stefee
                            • Feb 2023
                            • 1000
                            • Stefan
                            • Hemel Hempstead
                            I feel your pain, been there done that.
                              • 16157
                              Certainly fighting you all the way Bob. I have no doubt you'll sort all the issues. The engine and the interior are stunning.
                              How do you go about polishing the bodywork? What do you use?
