Revell 1:16 Rolls Royce Phantom II Continental (1934)
    This is going together very well. Negligible flash, parts fit perfectly, hardly any filling needed. The model, being 1:16 scale, is satisfyingly big. The engine block cover will be finished in Alclad 2 High Shine, and also the iconic radiator finished by Revell in chrome like many other parts but the radiator is not perfect. bluriusz modelled this kit in December 2012 and it looked really good.
    Here are 6 photos of what’s in the box and 4 of progress so far.
    Note that the front wheels can be steered. The engine is well detailed, the most fiddly part being the two sets of yellow ignition leads. Revell supplied thin yellow insulated electrical wire but it was very floppy and difficult to keep straight between bends, so I used 22 gauge (0.643 mm diameter) copper wire from a floristry supplier and painted it yellow. Cars at that time had two spark plugs per cylinder, for reliability, one fed by a magneto and the other by a coil. Both devices are modelled. The engine of the original had 7 litres and its petrol consumption would have been about 12 MPG!
    An identical car is for sale by The Real Car Co. for £135,000, repainted and the engine overhauled. My model will be in black for the mudguards and the top of the bonnet and British Racing Green for the sides.
    [ATTACH]78699.IPB[/ATTACH]
    [ATTACH]78700.IPB[/ATTACH]
    [ATTACH]78701.IPB[/ATTACH]
    [ATTACH]78702.IPB[/ATTACH]
    [ATTACH]78703.IPB[/ATTACH]
    [ATTACH]78704.IPB[/ATTACH]
    [ATTACH]78709.IPB[/ATTACH]
    [ATTACH]78706.IPB[/ATTACH]
    [ATTACH]78707.IPB[/ATTACH]
    [ATTACH]78708.IPB[/ATTACH]
    [ATTACH]78705.IPB[/ATTACH]
  • eddiesolo
    • Jul 2013
    • 11193
    Very clean paintwork Steve, great start should look superb with your attention to detail.
    Si
    • eddiesolo
      • Jul 2013
      • 11193
      One thing I have noticed is that the top of the doors has a walnut finish, is there decals for this?
      Si
        • 18302
        Been considering one of these classic cars from Revell. Looking at this it might just happen one day...
          Nice start Steve, will be definitely following this build
            Originally posted by \
            One thing I have noticed is that the top of the doors has a walnut finish, is there decals for this?Si
            No. The instrument panel is also shown with walnut veneer. The instructions state to paint this Revell "Wood Brown", 36382. The box illustration is misleading! I have collected some images from the Internet of burr walnut and will print these (after any scaling) and stick to the surfaces. Or perhaps use one to print a decal using inkjet decal paper. Here are some of those images:
            [ATTACH]78733.IPB[/ATTACH]
            [ATTACH]78734.IPB[/ATTACH]
            [ATTACH]78735.IPB[/ATTACH]
            [ATTACH]78736.IPB[/ATTACH]
              • 18302
              I would go for picture nr.2 printed onto decal film then a good gloss varnish ! nice.
                Been considering one of these classic cars from Revell. Looking at this it might just happen one day...Ian M
                Revell no longer list the Phantom, nor any vintage classic car kits.
                I can't find any models by Revell of vintage classic cars. Airfix do a 1939 Bentley Deluxe at 1:12 (£99 !), and do or did a 1948 MG sport at 1:16 but its not in their on-line catalogue (but is on the site of http://www.megahobby.com) That's quite a site, by the way.
                Have you found any vintage pre-war II classic car kits (not racing cars)?
                • eddiesolo
                  • Jul 2013
                  • 11193
                  I see, yes a bit misleading. As Ian points out the Walnut Burr should look great when you have rescaled and added it.
                  Revell do a 1/24 Mercedes Cabriolet. This is cheapest new edition of your Rolls: http://www.ebay.co.uk/itm/Revell-1-16-Rolls-Royce-Phantom-II-1934-model-kit-07459-/321273608849?pt=UK_ToysGames_ModelKits_ModelKits_J N&hash=item4acd663a91
                  Saw this too but it is expensive: http://www.ebay.co.uk/itm/LS-Morgan-Plus-8-Model-Kit-1-16-Scale-Complete-revell-airfix-agm-New-Vintage-/310884044905?pt=UK_ToysGames_ModelKits_ModelKits_J N&hash=item4862221069
                  If anyone fancies an older model variation this could be a bargain at 1/16: http://www.ebay.co.uk/itm/Revell-07462-1-16-Ford-Model-T-1912-/201041743119?pt=UK_ToysGames_ModelKits_ModelKits_J N&hash=item2ecf058d0f
                  There vintage range does seem very thin on the ground.
                  Si
                  • flyjoe180
                    • Jan 2012
                    • 12943
                    • Joe
                    • Earth
                    Nice work and start Steve.
                      Is a good start Steve.
                      I will follow this one
                      Polux
                      • monica
                        • Oct 2013
                        • 15169
                        a nice good start Steve ,looks good so far will keep an eye on this one
                        • tr1ckey66
                          • Mar 2009
                          • 3592
                          Hi Steve
                          Nice starter to the Roller. I think this will be an interesting build and the finished article will be stunning.
                          I suppose a '34 Rolls could even be used in a WW2 setting. Anyone know of a 1/16 Churchill figure?!
                          I'm looking forward to the progress on this Steve - great stuff!
                          Paul
                          Ps. You can buy 'off the shelf' wood veneer decals, they're used quite often in WW1 aircraft. Not sure you can buy Walnut though. Another method is to replicate the pattern with oil paint streaked over water based paint and then sealed with gloss varnish - this works very well.
                            I have had my eyes on this kit for awhile, will follow this build closely.
                              At first glance I thought that was a six inch rule alongside the body thinking it was small then I counted all the inches and saw it will be over a foot long.
                              Then I saw the quality of the engine and chassis
                              and then I thought mmmmm this is gonna be good
