Tamiya 14137 Yamaha Rd 500 or RZV 500
  • simontie
    • Jan 2010
    • 1515
    New build for first on the new site, Click image for larger version
ID:	1236893 see how I get on with this older kit the decal sheet is a bit yellow were the white is
ID:	1236894 so i scanned them and reprinted after i found the best setting and these look quite decent so I will use a mix of both Click image for larger version
    Printed on to clear paper as the kit is predominantly white so hoping they work out as i intend 🤞
    more as i get started
    Why is common sense not so common?
  • Nicko
    • Apr 2019
    • 1622
    • Nick
    • East Anglia
    I'm in for this one Simon. I bought the same kit secondhand a few years back and have yet to build it. My decals are in a similar condition too...
    Nick
    • simontie
      simontie commented
      Editing a comment
      If mine work successfully ill send you a copy
  • simontie
    • Jan 2010
    • 1515
    Kit ref should be 14037 sorry my mistake
    • HAWKERHUNTER
      • Feb 2012
      • 2042
      • Steve
      • Halifax, West Yorks.
      Chair pulled up for this one.
      • simontie
        • Jan 2010
        • 1515
ID:	1237338 Click image for larger version
ID:	1237339 Click image for larger version
ID:	1237340 Click image for larger version
ID:	1237341 Click image for larger version
        engine frame & body work still a bit todo but getting there
        • HAWKERHUNTER
          • Feb 2012
          • 2042
          • Steve
          Nice work on that engine.
            • 18301
            A nice bike. The real ones went like a rocket, lol.
            If you place the decal sheet by a window so they get natural light the UV should de-yellow them.
            • simontie
              • Jan 2010
              • 1515
              I will give that ago before i start thanks for the tip
              simon
              • simontie
                • Jan 2010
                • 1515
                Mid week not spent alot of time over the last week on this but its moving along slowly not the best pics but this is where i am, see how i get on over the next few days have also primed the fairing, used mr hobby white surface & filler primer seemed to go on well but ill see how it is tomorrow when its dry white is a nemesis i never quite get it right but practice as they say …. Click image for larger version
ID:	1238515 More as and when thanks for looking
                simon
                • HAWKERHUNTER
                  • Feb 2012
                  • 2042
                  • Steve
                  One day I might be brave enough to tackle a motorcycle kit. Coming on nicely Simon.
                  • simontie
                    • Jan 2010
                    • 1515
                    Sunday night and i have been busy just about completed the bike, working on the fairings and body work & all the other parts are completed
                    not assembled all the bits as yet but frame engine and rear end all fitted to be fair really went together well only 1 small issue the rear axle seemed short it wouldn't catch and screw in, so i dipped the screw in sprue glue and left it to set, once dry i cut the excess away unscrewed the axle and it worked really well, made a new number plate instead of the generic ones supplied
                    thanks for looking
                    simon
ID:	1239848 Click image for larger version
ID:	1239849 Click image for larger version
ID:	1239850 Click image for larger version
ID:	1239851 Click image for larger version
ID:	1239852 Click image for larger version
ID:	1239854 Click image for larger version
ID:	1239853 Click image for larger version
ID:	1239855 Click image for larger version
ID:	1239856 Click image for larger version
                    • HAWKERHUNTER
                      • Feb 2012
                      • 2042
                      • Steve
                      Looking very nice Si.
                      • simontie
                        • Jan 2010
                        • 1515
                        Well fairings tank front mud guard all painted, might have done this arse for face as i went red then white, hind sight should have been white red but its turned out really well.Click image for larger version  Name:	IMG_3593.jpg Views:	0 Size:	391.7 KB ID:	1240565 Click image for larger version  Name:	IMG_3596.jpg Views:	0 Size:	513.9 KB ID:	1240566 Click image for larger version  Name:	IMG_3597.jpg Views:	0 Size:	503.3 KB ID:	1240567 just the dreaded decals to do next, the rear seat I painted this should be a decal also but a hedged my bets that it wouldn’t sit right!! So i will cut the black pin strip out and use this only…
                        need to leave it a day or to for the clear coat to harden then ill press on more as i get them
                        thanks for looking and all your kind comments
                        simon
                        • HAWKERHUNTER
                          • Feb 2012
                          • 2042
                          • Steve
                          Those fairings have come out well Si. Good luck with all the decals.
                          • simontie
                            • Jan 2010
                            • 1515
                            Thanks i might need all the luck i can get 🙄
