1/16 1920's damaged and rusty van for dio.
  • eddiesolo
    • Jul 2013
    • 11193
    I am doing another mega rusty vehicle that will be on a small board for the RC tank fests-another eye candy piece and filler.
    I got this cheap as it was missing a front wheel, ideal for my plans
    I tried a new rust process to create flakes and lifting.
    I did not sand and prime the painted body prior to applying the pigments.
    While still wet I sprayed matt varnish, once dry this makes a white effect in places and cases the pigment to craze and lift from the original paintwork.
    I then gently scraped off the flakes and then re-applied using PVA undiluted, I then used more rust pigment to fill in the areas.
    Only other thing was remove the seat pad and add some springs.
    There is the grille and bonnet to sort and some other small details but so far it seems to be going well.
    Excellent work Si.
    I can see the rusty flakes so obviously what you did worked.
    • yak face
      • Jun 2009
      • 14076
      • Tony
      Amazing rust effects Si , looks totally real-superb!
        • 22851
        That's looking great already SiFi
          Another great rust bucket from the king of rust.
            • 18286
            Yep that's knackered, nice one Si
            • flyjoe180
              • Jan 2012
              • 12661
              • Joe
              • Earth
              Rusty and derelict, nicely done Si.
              • eddiesolo
                • Jul 2013
                • 11193
                Thanks guys, working on a dio board for it at the moment, hopefully should have it finished this week.
