I am posting this here because it is being built as a civilian machine as opposed to military.
[ATTACH]390111[/ATTACH]
If you have read my moaning about little problems with the HEMTT Tanker you may wonder why I am now going to build this model which is known to be a wee bit problematic. The fact that I got it cheap does help but the real reason is I really, really, wanted to build something like this, the difference is I bought it knowing of build issues and am willing to tackle it.
[ATTACH]390112[/ATTACH]
[ATTACH]390113[/ATTACH]
There are 15 sprues and some PE but only 4 sprues have an identification letter on them. This means a lot of time will be spend looking at instructions and then trying to find the part needed. There also seems to be no logic behind the numbering of parts so you might have to check a few sprues before you find the part you need.
One of the main problems with this kit is the tracks, as shown in the instructions they just do not work and it will be impossible to build them as per the book.
[ATTACH]390114[/ATTACH]
If you study the picture you can see that the link with the pin will not go through the other link as the pin is shouldered and will not fit. I think I have figured out a way to do it but it will involve a lot of work as each track link has 3 parts so that is 216 even before I start to modify them.
Andy.
Andy.
