1/35 Mirror Models Diamond T dump truck.
  • outrunner
    • Apr 2019
    • 2420
    This will be up next to take my mind off tanks.
    I have put it in civilian trucks as I am not going to do it in olive drab like the box art.
    There are 12 sprues, clear parts and a sheet of PE.
    Instructions seem clear enough but there is no sprue diagrams in there and the sprue numbers are so small I think labeling them with a bit of masking tape might make life easier.
    Not made up my mind about the colour yet but there are a couple of alternatives on the paint sheet.
    Not started it yet as I am building a small sprue stand from some bits I have lying about. Oops, looks like I have pictured the same sprue twice, must be an age thing.
    Andy.
  • Nicko
    • Apr 2019
    • 1637
    • Nick
    • East Anglia
    Looks pretty complicated, but I'll enjoy watching along..
    Nick
      Wow Andy, that looks like it's going to keep you busy. Have fun.
      • Mini Me
        • Jun 2018
        • 10711
        Unless I missed it in the pics I'm assuming it is 1/35 scale.........correct me if I'm mistaken. I really like the old Diamond T as well as the White and Auto Car that the Military used under contract. I'm so used to seeing these in OD green it will be fun to see a civilian version of this beast. Enjoy Andy.
        Rick H. :thumb2:
        • outrunner
          • Apr 2019
          • 2420
          Rick H. :thumb2:
          Yes it is 1/35, I forgot to put it in the title but I have fixed it now.
          Andy.
          • outrunner
            • Apr 2019
            • 2420
            Yes Peter, there are quite a few bits in the box.
            Andy.
            • outrunner
              • Apr 2019
              • 2420
              Made a start on this and got some sub assemblies put together. There are rather a lot of small, very small parts to this model and it seems to be smaller than I thought but as the real thing only had a 4 ton payload then it had no need to be huge. The twin rear wheel sets are not glued together yet as it would be a bit hard to paint them as one lump.
              [ATTACH]408277[/ATTACH]
              I was going to do this as a clean civilian build but having looked about on the net I may do it in the olive drab scheme with a load of weathering and dirt to cover my mistakes, we shall see. Oops, just noticed I have no olive drab paint and not much hope of getting delivery before Xmas.
              Andy.
                • 16162
                Hi Andy
                Very nice choice of kit. Mirror Models build up into nice, well detailed models but have many, fragile small parts. This looks typical.
                Watching with interest.
                  If it’s weathering you like, then I don’t think you’d need to hold back just because it’s in civilian colours. Sites where dump trucks work are generally not all that clean
                    Looks nicely detailed Andy, will follow along.
                      • 19103
                      Looks very detailed, almost like you're building it from individual nuts and bolts. It would look great in weathered red though.
                      • Allen Dewire
                        • 4741
                        • Allen
                        • Bamberg
                        OOOOhhh!!! Me likes this one.....Watching closely with a cold one in hand Sir......
                        Allen
                        • outrunner
                          • Apr 2019
                          • 2420
                          Slowly getting a bit more done with the truck, axles all made up and started on the chassis.
                          [ATTACH]408610[/ATTACH]
                          This model is not for someone who is looking for a quick build as there are so many small detailed parts.
                          I am including this picture for Paintguy as he said he was having a bit of hassle with his Gheko kit. This one is probably as fiddly as his.
                          [ATTACH]408611[/ATTACH]
                          So many small parts and they all have to be cut from the sprue with a blade or a razor saw (which I don't have) as the plastic starts to break if you use cutters and there seems to be a lot more sprue gates than most models I have built. Time taken to get the parts ready and having to do a bit of fettling to get them to fit doe not make it a bad kit, just one that needs a bit of care and attention.
                          Andy.
                          • Allen Dewire
                            • 4741
                            • Allen
                            • Bamberg
                            WOW Andy,
                            There sure are a lot of little parts to this puppy. I feel your pain without a razor saw to remove them. I have a solution for you though. Get you one of these and the problem is solved,
                            I can't guarantee the results, but it works for me. And, you even get a disc to remove the rest of the nasty sprue gate stubble!!! HTHs Sir.....
                            Allen
                              I see what you mean Andy. I must strike Mirror Models off my list if their kits are like that! :smiling5:
                              This one for instance, more gate than part lol
                              [ATTACH=CONFIG]n[/ATTACH]
                              Best of luck mate!
