Andrew's resurrected 1/72 Armourfast Farmhouse....
  • adt70hk
    • Sep 2019
    • 10552
    #91
    Originally posted by Jim R
    Hi Andrew
    Base looks to be progressing well. I agree with John it is great that Junior likes sharing modelling with you.
    The base is looking fantastic Andrew!!! Kudos to you both you and Junior. I see some of the ads on the newspaper under it offer things that would REALLY set it off. The fruit trees are a little pricey though........and maybe a tad out of scale too. I would check into the patio mounts though..........
    Allen
    Thanks guys. Much appreciated!!! I'll pass on your comments to Junior.
    Alan, please piont me in the directions of the fruit trees!! :smiling5:
    Thanks for stopping by.
    • adt70hk
      • Sep 2019
      • 10552
      #92
      Good morning all
      So I've finished the roof for the time being. I'll have one final look once the main house structure has been weathered but I don't think it will need much more work:
      • The vertical separation between the columns of the tiles had been lost a bit. I didn't want to created a full on and potentially false looking 'black shadow' but something a bit softer. I did this with a couple of thin coats of a thin pin wash made from equal measures of Vallejo Game Wash Umber 73.203 and Sepia 73.200, plus a few drops of thinner and flow aid.
      • To calm the tiles down a bit and given them an older look, I created a very thin wash from Life Colors Rust and Dust set, specifically UA705 Dust Type 1 as it has a slightly reddish tint. Again the roof had a couple of coats.
      ACW as usual.
      Re-defining the vertical separation.
      The before
      The after - a subtle separation, which is what I was after.
      The 'worn tile' wash
      Life Colour UA705 in the centre.
      Two coats of the left of the brush - one coat to the right.
      The right hand side two coats, left hand side none.
      The finished effect.....the overhead shot looks a bit heavier than in reality due to the angle
        • 19130
        Loving that Andrew. Those washes have really made this pop….
        • adt70hk
          • Sep 2019
          • 10552
          #94
          Thanks Tim. Quite pleased with them myself!!
          ATB
          • eddiesolo
            • Jul 2013
            • 11193
            #95
            Now that is a nice bit of roof tiling detail Andrew, the base is coming along also...going to be cracker of a setting when done.
            • adt70hk
              • Sep 2019
              • 10552
              #96
              Thanks Si. Much appreciated! I'll try not to let you down!! :smiling5:
              ATB
              • eddiesolo
                • Jul 2013
                • 11193
                #97
                ATB
                I very much doubt you could let me down mate, cracking work and detailing.
                  • 16301
                  Hi Andrew
                  The roof was definitely worth the time and effort. The difference is subtle but looks much more realistic.
                  • Mark1
                    • Apr 2021
                    • 4156
                    #99
                    Looking good.
                    • adt70hk
                      • Sep 2019
                      • 10552
                      #100
                      Hi Andrew
                      Originally posted by Mark1
                      Looking good.
                      Thanks guys, I'm pretty pleased with it!
                      ATB
                      • scottie3158
                        • 14635
                        • Holbeach
                        #101
                        looking the nuts.
                        • adt70hk
                          • Sep 2019
                          • 10552
                          #102
                          looking the nuts.
                          Why thank you kind sir!!
                          • adt70hk
                            • Sep 2019
                            • 10552
                            #103
                            Good morning all
                            So not much bench time over the past couple of weeks but the house is finished - I think.
                            I still have the windows, leaves for the climber and a final coat of varnish to do but I want to finish the base before I do that, just to make sure it all ties in and doesn't need any final tweaks.
                            I've added some wooden batons to the inside of the upper walls up to the roofline. They wall were a bowed out a bit and didn't sit properly - I tried to ignore it but couldn't. It's not 100% 'perfect' but at normal viewing distance you can't see it.
                            As per Tim's recommendation I got a bottle of Vallejo's Model Game Wash Pale Grey 73.202 and, as he hinted at in his post, it's pretty versatile:
                            • As per his suggestion a wash over the walls does add some nice light shadow and makes the walls 'pop' a bit more.
                            • It turns out it's pretty good at making nice white window frames and sills look dirty.
                            • It's also good at making the shutters painted in Vallejo Model Air Faded PRU Blue 71.109, look more warn and faded.
                            • I also added a light coat under each of the window sills to create some subtle shadow/dirt.
                            • I tries adding water marks where it's run off the edges of the window sills....not 100% happy but it will do.
                            • It also helped to tone down the moss/mould effect I trying to achieve along the bottom of the wall,to represent where damp and rain water had helped it grow. It's not 'perfect' but will do for now until the base is finished and I can give it one final look
                            • I also mixed it with Vallejo Model Wash Grey 76.516 (quite a dark grey) to create a mid-ish tone grey wash. I used this to redefine the shutter planks where the pale grey had gathered as I gave them the faded look. At this scale I didn't want something too dark as I thought it would look out of place and I have to say I think I hit the right tone (pun intended!! :smiling5:
                            So all in all Pale Grey 73.202 does seem to be pretty versatile! Thanks again Tim!
                            ACW as usual peeps!!
                            ATB
                            Batons in place and painted
                            The rear elevation as I think this gives the best overall impression
                            On the base.....
                            ignore the white under the walls you can see, this is masking to keep PVA glue off the base for when I do the grass.
                              • 19130
                              Looking really good Andrew.
                              With respect to the VJ washes, glad you like them :thumb2: I find the more I use them the more I find other uses for them. They are a great addition to the painters armoury. I don’t think I paint anything now without using them somewhere along the line.
                              • Mini Me
                                • Jun 2018
                                • 10711
                                #105
                                A great suggestion Tim and well employed Andy.........The results are more than evident. I particularly like the results around the windows......that under shading does make 'em really stand out. :thumb2:
