Hey guys. Here's my completed creek diorama. I don't think I sealed the board up enough because when I poured the realistic water it really warped the board and pulled some of the celluclay away from the walls. I'll try and fix it someday, just add in something to fill the gaps.
I used real foliage and branches from a creek by our house for the little bits. The leaves are actually real leaves that I ground up and cut with scissors to try and make them as small as possible. I used heavy acrylic gel medium for the ripples in the water. Those took a week to fully clear up (goes on milky white) and then I put a coat of Future on top to really gloss it up. When I put the Future on it reactivated the gel medium and the whole thing looked like a sheet of ice. It looked really cool but as it dried it all turned clear again. I need to get something else to take the pictures on as my current setup isn't big enough to handle something like this obviously. Someday...
I tried adding a couple things around the downed tree's base but wasn't happy with anything that I did so it sits empty for now. Maybe I'll add some more shrubs or something at some point.
Hope you like it.
[ATTACH]100180.IPB[/ATTACH]
[ATTACH]100181.IPB[/ATTACH]
[ATTACH]100182.IPB[/ATTACH]
[ATTACH]100183.IPB[/ATTACH]
[ATTACH]100185.IPB[/ATTACH]
[ATTACH]100186.IPB[/ATTACH]
[ATTACH]100187.IPB[/ATTACH]
[ATTACH]100188.IPB[/ATTACH]
[ATTACH]100189.IPB[/ATTACH]
[ATTACH]100191.IPB[/ATTACH]
[ATTACH]100192.IPB[/ATTACH]
[ATTACH]100193.IPB[/ATTACH]
Hope you like it.
