Best material for base board on a diorama?
  • pjgtech
    • Dec 2023
    • 1168
    • Peter
    • Swale Kent UK
    With an upcoming diorama for the PBI GB, I will need a decent base upon which to build.
    What materials do people use?
    For the couple of small diorama's that I've built so far, I have just used plain foam type board, eg: 5mm Polyester type A4 boards.
    They were ok, but I am slightly concerned that my next diorama will be a bit bigger, approx 450mm by 250-300mm, ish....
    Foam board is ok, but its a bit light and slightly flexible, I suppose I could double it up and stagger the joints maybe?
    Anyway, open to ideas and suggestions on what others use as a base for diorama's.
  • Airborne01
    • Mar 2021
    • 4162
    • Steve
    • Essex
    I use MDF, old picture frames or else anything else that seems appropriate! (PS reference a later post that I've just replied to - don't even think of leaving - I wanna see your PBI production!)
    PM me if there's something you would like to talk/rant over mate!)
    • pjgtech
      pjgtech commented
      Editing a comment
      Thanx for the offer, 8-) but not me leaving mate, its someone else, but sad to see if they do go....
  • PaulTRose
    • Jun 2013
    • 6815
    • Tattooine
    Fibre board......i just bought an A2 size 5mm thick....less than a fiver from hobbycraft.....going to cut it into 3 stick together to make 15mm thick.......by time ive added some filler im hoping its going to quite sturdy
    I have ysed sheet polystyrene in the past
    How big do you need?
    Per Ardua
    • pjgtech
      • Dec 2023
      • 1168
      • Peter
      • Swale Kent UK
      My Dio will be about 450 x 250 ish, I have some of the A4 foam boards (5mm thick), but one won't be enough, so may need to stick some together?
      Have also looked at hardboard, and MDF, and maybe even some solid insulation type board?
      • Airborne01
        • Mar 2021
        • 4162
        • Steve
        • Essex
        MDF is good, just be careful in the preparation mste
