(yet another) sideproject: Half - Timbered Tudor-esque House w. smoker and fireplace and lantern
  • Steven
    • May 2018
    • 594
    Hello all
    work continues on my Syrian build featuring a XPS foam building but taking a meandering trip around youtube got me interested in other types of foam buildings and I find myself once again sidetracked working on a building with a fireplace, smoker unit (remote controlled) and - eventually- a flickering lantern
    Work is progressing on the fireplace with a standard 3mm flickering diode wrapped in orange and yellow filter. wood is real wood with some ash pastels added, and a wash or two, tiles on the fireplace are cast in plaster.
    furniture are from shiftinglands and might need either a staining or some washes - additional furniture might be a bed and a rocking chair
    I have been using templates from shiftinglands for the half-timbering and should be 28mm I guess - furniture fits a 28mmm figure bit the Windows are too large but this is all just for the fun of it :-)
    This is the view from the outside - the room will have limited viewing angle through two windos.
    Outtake for the smoking unit housed in the adjacent room with tubes and connector housed in the "Attic"
    In Operation - it is not exactly silent but I hope being incased in foam will have a dampning effect
    C&C is welcome :-)
  • Bobby Conkers
    • Jan 2020
    • 529
    This sort of stuff is going to be my next branch out from plastic kits. Looks marvellous, I shall be following you with interest!
      When you add lighting to a build it definitely takes it to the next level Steven ,now with the addition of the smoke unit it even tops that .Keep it up .
      Chris Boatman would enjoy this .
      • boatman
        • Nov 2018
        • 14593
        • christopher
        • NORFOLK UK
        HI Steven yes like John says im instrested in your smoke would you mind showing me how you did it an what things you used like ? as i need another smoke unit for my tiger as it has two funnels cheers
        chris the boatman
        • adt70hk
          • Sep 2019
          • 10553
          Coming on VERY nicely indeed!!!
          • Steven
            • May 2018
            • 594
            chris the boatman
            Hello Chris
            Pardon the lateness of the reply
            I am going to use a smoker from Wayne's workshop it is remote controlled and cordless is does the job but is quite noisy I hope to remedy this problem by incase it in foam in the room next to the living room
            • Steven
              • May 2018
              • 594
              In action
