F-16 for parts reclamation
    Thanks Joe I am in he middle of building a second pallet to go on the dio as well.
      Just caught up with this, and it looks really good, and a great idea ! Looking forward to seeing how it turns out
      Cheers, Neil
        Originally posted by \
        Just caught up with this, and it looks really good, and a great idea ! Looking forward to seeing how it turns out Cheers, Neil
        Thanks Neil
          Looking great Terry ,its like I'm back at Davis Montham all over again!
            Thanks Trey that compliment coming from someone who has actually been there is amazing.
              This is coming along very nice Terry
              The pallet is great idea
                Thanks Polux
                • Lee W
                  • Feb 2014
                  • 4704
                  • Lee
                  • Sherborne
                  #53
                  This is turning out very nicely Terry, the weathering is really effective
                  Lee
                  • Dave W
                    • Jan 2011
                    • 4713
                    #54
                    This is looking great Terry.I like the base with tufts of grass.Thinking of doing something similar for my Maryland.Not sure where to start though.
                      Lee and Dave thanks for the kind remarks.
                      Today I have carried on doing a bit more weathering to one of the tanks as can be seen in the photos the difference is quite vast. I have used crushed pastel for the yellow dusting as the Flory's sand is to red and the Humbrol powder would have made it look jaundiced. I have also weatherd the main undercarriage doors and the tressles that he airframe sits on.
                        It does actually help if you remember to add the photos you are on about eejut. [ATTACH]85378.IPB[/ATTACH]
                        [ATTACH]85379.IPB[/ATTACH]
                        [ATTACH]85380.IPB[/ATTACH]
                        [ATTACH]85381.IPB[/ATTACH]
                        [ATTACH]85382.IPB[/ATTACH]
                        [ATTACH]85383.IPB[/ATTACH]
                        [ATTACH]85384.IPB[/ATTACH]
                        [ATTACH]85385.IPB[/ATTACH]
                        [ATTACH]85386.IPB[/ATTACH]
                        [ATTACH]85387.IPB[/ATTACH]
                        [ATTACH]85388.IPB[/ATTACH]
                        The belly tank is not yet finished.
                          Dave I started with a bit of MDF from an old headboard cut to size. I then gave it a rub over with a course sandpaper followed by a good brush off. Once this was completed I spread a cheap filler over the whole board (done in two stages due to running out). While doing this I set the tressles in where I wanted them.Once dry I brushed PVA over the plaster and then sprinkled fine sand all over. At this point I wasn't to happy with the way it looked so I purchased some railway board sand from the LMS then repeated the above process. At thay is stage even with the aircraft and hummer sat on the board it looked a bit stark so I went on evilbay and purchaesd two boxes of the grass one was a sample box with different colours in and the other was desert grass. I found it quite hard not to leave the grass looking staged and I hope I have managed that. Before starting I already had an idea of what I wanted the dio to look like I hope this helps.
                            The belly tank is now finished and in place as is one of the under wing drop tanks. I have also put some of the under [ATTACH]85440.IPB[/ATTACH]
                            [ATTACH]85441.IPB[/ATTACH]
                            [ATTACH]85442.IPB[/ATTACH]
                            [ATTACH]85443.IPB[/ATTACH]
                            [ATTACH]85444.IPB[/ATTACH]
                            [ATTACH]85445.IPB[/ATTACH]
                            [ATTACH]85446.IPB[/ATTACH]
                            [ATTACH]85447.IPB[/ATTACH]
                            [ATTACH]85448.IPB[/ATTACH]
                            [ATTACH]85449.IPB[/ATTACH]
                            carraige assembly on but left it hanging.
                              That's looking good Terry, there's a lot of detail going into this one!
                              Just a point, bird sand (£1 from Wilkos) is great for dios, nice small grains.
                                Thanks Patrick I shall keep that in mind.
