Very nice work Ron. I love the lighting in that first picture and looking forward to the finished piece
Spanner's Revell 1/72 Dam Buster Lancaster. 1958 tooling.
Thanks chaps...
I've started work on the dam and its surroundings.
I penciled the shape and then painted the dam on a length of card, cut out the outline and overflow openings etc, and then rested it in front of a large piece of black card.
This image is obviously way too light. I'll see how it looks when Mr. Sun has gone to bo- bo's!
Early days yet, but it's a start.
Cheers.
RonAttached Files👍 2🥰 1Comment
Cheers Jim.
As the attack was at night, I'm hoping the final frame will be more of a 'Silly Wet' of the dam, rather than what you see above.
Also, I need to iron out the lake surface a tad.
The trouble is, at this time of year it doesn't go dark 'till quite late. A bit past this old farts bed time. So one evening soon I'll have to try and stay up and take some darkness shots!
Thanks for the continued interest.
RonComment
Thanks for the input Paul and Tony.
Second go....and onwards with the 'Cunning Plan'1
The outline of the dam looks a bit wonky. This is due to the paper I painted the dam on warping a bit. a good ironing will sort things out - If I knew how to use one, that is!
Before it gets too warm today, I've had a mess about with the dam and darkened the structure and darkened the wooded areas either side of the dam.
I also flattened out the water a tad.
The photo was taken around the same time as the previous image, so just a bit of extra black paint makes a fair bit of difference....
I will see how it looks at dusk tonight.
Later 'I'll add the aircraft and then see where I can 'Fettle' things a bit more.
Getting there slowly - Hopefully!
Ron👍 5🥰 2Comment
