Yes, I know they never actually sailed together, but I have just built the Bismarck and the Scharnhorst in the same tiny (1:1200) scale and I was so impressed with them that I wanted to do a little diorama to show them off.
NB: not quite finished the Scharnhorst yet, but its almost done.
A little base with a seascape seemed appropriate? Maybe some sort of rocky background or even some cliffs?
I had lots of spare off cuts of foam base board, so cobbled together a small base.
I then cobbled together a raised corner using smaller off cuts of foam board and some more rock/cliffs from two small pieces of old packaging foam.
By placing them on the base board I got an idea of what the basic layout could look like.
I then put some fine modelling filler and the foam blocks to add more texture...
At this stage I also glued on some thick water colour paper onto the base board, as I will be painting the base, before adding the water solution. Then I glued those now set foam pieces to the base board...
Then I added some Ammo/Mig "Mud" putty to fill a few gaps and add even more texture....
At this stage I also marked out where the ships would sit, being flat bottomed I did not need to sculp recesses into the base, or so I thought...
NB: the line at the bottom of the base board is where I might cute the base board down as it might look a bit too big/empty otherwise, we'll see.
