Under Watchful Eyes
  • Steve Brodie
    • Sep 2014
    • 4652
    Under Watchful Eyes
    Story;
    A warrior patrol stops at a road block and a boy with his grandpa approaches, a British Soldier looks on from behind the barricade whilst the boy walks towards the soldier with a flower in his hand, the crew of the Warrior are keeping an eye on what’s going on from their lofty perch being in communication with the rest of the soldiers in the back of the warrior. The grandpa is also keeping an eye on his grandson and the soldier and shouts across “ahlan as-salaam ‘alaykum” peace be with you my friend.
    Jersey Barriers
    These (4 in total) have been made using the mould that comes in the Meng barrier set. They have been distressed with a sharp knife and one of them has been bounced around with a small burr head in a mini drill, I will most likely do the same to the rest of them. Floral craft wire has been used to make the lifting handles, (wire bent over a paintbrush shaft), made slightly different for each one.
    [ATTACH]103888.IPB[/ATTACH]
    [ATTACH]103889.IPB[/ATTACH]
    [ATTACH]103890.IPB[/ATTACH]
  • Richi72
    • Sep 2013
    • 1100
    Ok, so being in this kind of situation in real life more than once, I will follow this build.
    Cheers Richi
    • Steve Brodie
      • Sep 2014
      • 4652
      Cheers Richi
      No pressure then :-). Hopefully I get it right
      • monica
        • Oct 2013
        • 15169
        i like the sounds of this,and will be keeping a watchful eye my shelf,
        do like the looks of the barrier ,Steve and what your done makes it look real like,
        I used them in my zombie Dio,as well,
          • 22983
          Sounds good to me also so I'm in watching this
          • takeslousyphotos
            • Apr 2013
            • 3900
            I'll be keeping a watchful eye on this ....Sounds interesting.
            • Steve Brodie
              • Sep 2014
              • 4652
              Work done on distressing the Jersey barriers, need to add a couple of washes, dust/sand.
              [ATTACH]104460.IPB[/ATTACH]
              [ATTACH]104461.IPB[/ATTACH]
              [ATTACH]104462.IPB[/ATTACH]
                Heard of Jersey Wonders, Jersey Potatoes and Jersey Cows as I live among them (slight distance between ?) But not Jersey Barriers.
                • Steve Brodie
                  • Sep 2014
                  • 4652
                  Tut, Tut - http://en.wikipedia.org/wiki/Jersey_barrier
                    In that case Steve they should be known as New Jersey Barriers. We are the original Jersey. All the others are imposters.
                    • monica
                      • Oct 2013
                      • 15169
                      there turned out so well Steve,real like that look with the cracked paint on the bottom on the middle one,
                      • Steve Brodie
                        • Sep 2014
                        • 4652
                        Jersey Barriers completed;
                        [ATTACH]106946.IPB[/ATTACH]
                        [ATTACH]106947.IPB[/ATTACH]
                        Just need to add to base with figures and Warrior.
                        • Steve Brodie
                          • Sep 2014
                          • 4652
                          Completed;
