My first diorama
  • takeslousyphotos
    • Apr 2013
    • 3900
    #16
    That is a cracking job so far Josh ......... I'll be watching your progress with this one.
      Thanks guys. Does anyone have any tips on using static grass ? Do you leave as is or do you use a fixer to strengthen ?
        • 22954
        #18
        That's coming along very nicely Josh.
        Sorry I can't help with the static grass never used it
        • Richi72
          • Sep 2013
          • 1100
          #19
          Hi Josh,
          as I can see from you pictures you used long grass.
          you can leave it the way it sits or you can use some clear coat to strengthen it a bit.
          I recommend the clear coat if you want to drybrush the grass later on, but if not leave it like it sits.
          Hope it helps
          Cheers Richi
            Hi Josh that looks like nice work, I will be following eagerly.
            scott
            • monica
              • Oct 2013
              • 15169
              #21
              looking good Josh,
              I tend to agree with Richi,and when i do leave pretty much along once set,
              maybe a little bit of a comb,
              • flyjoe180
                • Jan 2012
                • 12938
                • Joe
                • Earth
                #22
                That is looking great Josh, nice work so far.
                  Update:
                  Not sure if I like the colour scheme. The brown paint was a little too think and has also left streak s
                  [ATTACH]106998.IPB[/ATTACH]
