1/35 Mountain rescue
  • Snowman
    • Oct 2014
    • 2111
    #106
    That is a nice molded figure for the intended victim. B|
    Who supplies/makes it?
    oops, missed youre response to Monica.. :$
    • Steve Brodie
      • Sep 2014
      • 4652
      #107
      Originally posted by Pikeman
      Hello
      this is the resin kit I have chosen for my injured climber.
      I was not easy finding a kit to look good on a stratcher but I think this will do the trick.
      [ATTACH]261934.IPB[/ATTACH]
      [ATTACH]261927.IPB[/ATTACH]
      Dont forget to 'chop' her overhanging arm off (so to speak), They wouldn't Evac her unless she was fully strapped into the streacher. The other thing may be the pose, of her lying on her side. Did find this one on t'net - Resicast Figure, chop the body at the waist line, then using two part epoxy create a 'shape for the legs and cover this all with a homemade blanket (tissue paper soaked in white glue) or lead foil. - Hope you dont mind my little suggestions.
      • Steve Brodie
        • Sep 2014
        • 4652
        #108
        OR if you are feeling brave, make a body shape out of two part epoxy, and add a hornet head - Hornet sleeping Heads
        • Pikeman
          • Feb 2016
          • 1312
          #109
          Cheers snowman thanks for your kind words .
          yeah masterclub have some nice figures
          • Pikeman
            • Feb 2016
            • 1312
            #110
            Think your suggestion is great but I am only a beginner and not sure if I could make it look ok still learning.
            got metal etch straps for stretcher and was thinking about chopping her arm off.
            great tips Steve thank you for your kind words
            • Pikeman
              • Feb 2016
              • 1312
              #111
              not sure I can do that I have only just started with figures only done 6
              prob look better your way
              • Steve Brodie
                • Sep 2014
                • 4652
                #112
                Bear with me on this (all i had on my desk at work) but;
                Get a triangle teabag, cut it open and remove most of the tea;
                Put into a 1/35 size shape of a body - use a standing figure to get size near enough and glue with white glue
                Chop off a head from a spare figure, or use one from Hornet Heads and attach to the new body
                Create a blanket from tissue soaked in white glue (can dye the glue with acrylic paint, and hay presto
                If nothing else , i hope this gave you a laugh.
                • Pikeman
                  • Feb 2016
                  • 1312
                  #113
                  [ATTACH]261963.IPB[/ATTACH]
                  [ATTACH]261964.IPB[/ATTACH]
                  [ATTACH]261965.IPB[/ATTACH]
                  [ATTACH]261966.IPB[/ATTACH]
                  What a good idea,not sure I would get a great result but might try both ways.
                  cheers Steve great tip.hope nobody seen you making a teabag body at work
                  • monica
                    • Oct 2013
                    • 15169
                    #114
                    that's great Steve,I do real like that idea,well done,
                    • Pikeman
                      • Feb 2016
                      • 1312
                      #115
                      Well I think this one is done,should  look better once she is on the stratcher.
                      What's your thought good or bad
                      • Pikeman
                        • Feb 2016
                        • 1312
                        #116
                        Little update
                        added some wash to the white areas and made them look a little worn, also put main rotor blades on just for photo shot (not fixed) to see how it looks.
                        still have doors to put on and tail rota and bits and bobs
                        whats your thoughts cheers Stu
                        • Lee W
                          • Feb 2014
                          • 4663
                          • Lee
                          • Sherborne
                          #117
                          Liking this Stu
                          Lee
                          • Pikeman
                            • Feb 2016
                            • 1312
                            #118
                            Originally posted by mr grumpylee
                            Liking this Stu
                            Lee
                            Cheers Lee really appreciate it and glad you like it so far
                            • monica
                              • Oct 2013
                              • 15169
                              #119
                              looking good Stuart,do like the frosty windows,
                                This is looking good Stuart
