BMP -2 In Aleppo - Buildings construction
  • Steven
    • May 2018
    • 594
    #91
    So I have been working to undo the F*** up
    Redid the rendering of the balconies working on the rebar
    Done some work on the rebars right now they are all rusty but parts of them will be covered by a residual concrete
    also, the edge where pieces have broken of will be covered in a fine mix of plaster and white glue
    FSA flag on roller gate done
    - these would have been hastily added, so I have not bothered too much with the artistic look - the gate will have some holes in it when I can bare to do it.....
      Steven.
      Great save, love the texture you have , keep some of that rust on the rebar.
      All is not lost by any means .:thumb2::thumb2::thumb2::nerd:
      John.
      • Steven
        • May 2018
        • 594
        #93
        Thanks John :-)
        Did some more work on the balconies:
        Panels painted - not sure whether I will go with this color- might do pastel Red or Green - thoughts? also the bulletholes on the left hand side are oversized
        I did some detailing on the edges
        :rolling::rolling:Makes quite a difference - before:
        After:
        The facade - Redone rendering ,done some work on the AC units - will be heavily wheathered
        Heaps of details yet to do - and this is just the facade:rolling:
        See ya'
          Looking fine Steven .
          John .
          • Steven
            • May 2018
            • 594
            #95
            Did some streaking under the acs i will supplement these with some rusty streaks as well from the mounting brackets
            I word of caution when doing effect paint ( here Ak) on absorbent plaster based surfaces such as pollyfilla there is no waiting period - start blending right away
            even though i have varnish the facade the paint was absorbed into the surface very quickly
            i would also recommend thinning the effect paint
              It's really surprising how quickly the paint is absorbed, just shows how much of the varnish went the same way !
              • scottie3158
                • 14635
                • Holbeach
                #97
                Steven,
                This gets better everytime I look in.
                • Steven
                  • May 2018
                  • 594
                  #98
                  Indeed;,John still went in pretty fast despite a coat of white glue AND two coats of varnish
                  Paul, thanks a lot :hungry:
                  • Steven
                    • May 2018
                    • 594
                    #99
                    weathering the AC units - what do you think?
                    before
                    After:
                      Just the job Steven, any more and it might look over done .
                      John .
                      • Steven
                        • May 2018
                        • 594
                        #101
                        You are quite right John it is a fine line but maybe a few rust streaks might not be amiss?
                        • Steven
                          • May 2018
                          • 594
                          #102
                          I am working quite aimless rather than sticking to finishing sections of the building I start something new
                          Although most of my ref pics show roller gates being used in doorways and the dio has two of them but i thought a might add another type in the doorway of the section of the house that is most destroyed
                          So, pie tin foil and plast strips when it is done i hopefully will be able to buckle it a bit - blast damage- and have it hanging form one hinge
                            A few maybe , just on the edges Steven. Just had another look at the earlier photos, what about where the unit is fixed to the support rails, that maybe would be an area where paint would have been knocked off when they were fitting.
                            Do like the idea of the foil, can't really think of any better to represent buckled metal, look fwd to seeing the outcome.
                            John.
                            • Steven
                              • May 2018
                              • 594
                              #104
                              John.
                              The mounting brackets have been weathered with a spotty rusty appearance - well spotted
                              The Door:
                              The door almost done - still in fairly god nick - that will change...
                              • Steven
                                • May 2018
                                • 594
                                #105
                                Bigger building
                                A bit of progress on the facade of the bigger building roller gate is in, as is the last of the AC - gate is a bit too shiny but will be more subtle when the whole lot is dusted with pigments.
                                Smaller
                                The plan: keeping the nice bright white surface of the pollyfilla , varnish it and then do subtle washes to weather, niiice, subtle effect , right?
                                Nooooo....
                                The harsh modelling reality: Even with the varnish, literally the thinnest wash I have ever done and immediate dubbing following, the damn.. thing suck up paint like you would not believe. The result is a weathering not suitable - even for wartime Aleppo - this is a do over, I will have to paint the rendering and then do washes
                                As this is a convenience store I will be adding some shelfs to the sides, a counter in the center of the room discarded boxes and crates on the floor most of this will only be partially visible as the the collapsed ceiling will hide most of it.
                                'til next time
                                C&C is very welcomed
