Some where on the Eastern Front 1942 /43 1/35 scale
    453, you really are hopeless!
    Perhaps a move to a different ward might help...The one Sister Muldoon runs! ..... :anguished::anguished:
    570
    There is no known treatment 570, no no not Sister Muldoon, please anyone else.:fearful::flushed::tired::sad:
    Originally posted by BigGreg
    looks realy neat i can't wait to it painted and heavy weathered.. :-)
    Greg thank you, will be quite a " smashing break out " The Germans won't know what's hit then !
    Originally posted by SimonT
    John - sorry, forgot to come back and clarify.......
    [ATTACH=CONFIG]n1100762[/ATTACH]
    the two halves of the drive sprocket should fit together so that gap, arrowed, is not there
    Those large bumps either side fit together to form a bar between the front and back faces - the track link teeth drag on these bars as the wheel rotates and that is what produces motion
    Oh I see, should I cut them apart and reglue ? Thank you.
    I'd left the rear track guards off for ease of fitting the tracks.
    Originally posted by minitnkr
    Shaping up nicely Dzohn. I think you guys in Europa are going to have to break down & invest in air conditioning or move your bedrooms into the basement before you all expire. It doesn't look like summers of yore are going to return in our lifetimes. PaulE
    Hi Paul , thank you, think your correct with the air con, I can see there being a sales boom
    Today being much cooler I managed fair amount on the diorama base
    Taking note from 570 perfect bases I've decided to try to improve.
    Using some cardboard and white card I've started to make a wraparound with only the front open .
    The white card is glued to another section of cardboard, which in turn is glued to the large sheet.
    This has given a lip around , so the roofing frame has a fixing point.
    There will be afair amount of roofing sheets blown off, exposing the steel frame
    With this in mind I have increased the detail
    I knew one day those bolt heads would come in handy :nerd:
    Thanks for following.
    John .
    • spanner570
      • 15594
      #167
      Very nice 453.
      Good work going on for sure.... :thumb2:
      570
        Blingtastic!
          Very nice 453.
          Good work going on for sure.... :thumb2:5
          Very nice 453.
          Thanks 570, glad you approve .
          Originally posted by Peter Day
          Blingtastic!
          Hi Peter,:smiling2: thank you .
            Very nice 453.
            570
            Glad you approve Sir .
            453
            • Mickc1440
              • 4825
              #171
              That's nice JR the rabbles DIO's certainly are on the up and up
              • Si Benson
                • 3572
                #172
                Coming together nicely John:thumb2:
                  That's kind of you Mick, thanks.
                  Hi Si, cheers mate, I keep trying, more time now its cooler and wet .:smiling:
                  Managed to get the rest of the white card stuck down on the dio back and sides.
                  Going to carry on with the roof joists, but at some point need to get put the tank through the wall, before I manage to block myself in.
                  Some paints should be here from the Scale Model Shop this week , this will enable final painting to take place of the tank.
                  Have a good week all .
                  John.
                  • Richard48
                    • 2109
                    • Richard
                    • Clacton on Sea
                    #174
                    Sorry for being late on parade dear boy.What a mighty fine job you are doing of this Sig sig.Some very nimble work Captain John,Ive got a huge stack of DML 1.35th soldiers on shelf.If you ever need a paricular box i might have them.
                    Carry on Carruthers.
                    Pip pip onk onk.
                    Richard.
                      Originally posted by Richard48
                      Sorry for being late on parade dear boy.What a mighty fine job you are doing of this Sig sig.Some very nimble work Captain John,Ive got a huge stack of DML 1.35th soldiers on shelf.If you ever need a particular
                      John. box i might have them.
                      Pip pip onk onk.
                      Richard.
                      Thanks Richard, i'd just pmd you as well . As for figures thank you , I will ask next time I need any.
                      • Steve Jones
                        • 6615
                        #176
                        Lovin the base. Any man hole covers in the street?.
                          Cheers Steve ,I did think about it,but there will be loads of debris, but could put a drain in near the wall as there will be guttering.
                          This is where we are today .
                          Another section of steel roofing.C/W with Bolts ! Well they are nearly rivit:tongue-out3::tongue-out3: like
                          Also made a quick jig, hopefully will help to keep the angle right .
                          Gardening in morning but later hope to cut our a shed load of angle plates.
                          Thanks for looking in.
                          John .
                          • Mini Me
                            • Jun 2018
                            • 10711
                            #178
                            JR, that is a "fixture". Jig is now an inappropriate word as somewhere down the line someone smarter than all of us decided it had "racial connotations" LOL!!!
                            :smiling5: Cheers, Rick H.
                            • scottie3158
                              • 14432
                              • Holbeach
                              #179
                              John,
                              The great work continues.
                                Good God is no word safe from these Snowflakes !
                                John,
                                Thanks Paul .
