1/72 Takom Russian Tractors. Special Delivery
    Thanks Steve.
    I've been playing about with some fencing for the cliff top. Drilled cocktail sticks and 0.2mm silver wire for a post & galvanised wire look. Maybe a bit chunky but doesn't seem massively out of scale I reckon.
    [ATTACH]362078[/ATTACH]
    [ATTACH]362079[/ATTACH]
    • Allen Dewire
      • 4741
      • Allen
      • Bamberg
      #62
      Yeah Baby!!! Love the Ducati!!!...…………...
      • spanner570
        • 15599
        #63
        Sorry, I never spotted the bike first time!
        • minitnkr
          • 7809
          • Dayton, OH USA
          #64
          So, a rugby playing biker:smiling:? :smiling:That top is very flattering BTW. PaulE
          • Lee Drennen
            • 7738
            #65
            Very nice work Andy love those trucks
              Thanks Lee. Hoping I can do them justice with the dio.
                Got home from work and the first lot of filler still isn't quite dry on the thickest parts, where it still needs building up some more, so that was tonight's plans thwarted. Rock face is nice and hard though so at least I know the rest will dry eventually.
                So instead I undercoated the last truck in Vallejo Rust. I'm going to try my luck with hairspray chipping for the first time and starting out with a camo scheme. What could possibly go wrong! :smiling5:
                [ATTACH]362163[/ATTACH]
                  So, that hairspray chipping lark is a black art. Looks so easy in the seventy million videos I've watched on the subject :smiling5:
                  My main issue is getting it fine enough to look in scale. My test pieces were more like 1/35 and looked fine, but 1/72 is a different matter, it just looks like big chunks of paint have flaked off. I played around with different amounts of HS, drying times, paint types etc. Some of it seems to have worked OK, some not so well.
                  Anyway, onto the pictures. Scratched load deck came out pretty well I think. I used Mr Color over the hairspray as I figured the lacquer paints would be harder to chip, giving the finer effect I was after
                  [ATTACH]362489[/ATTACH]
                  Chassis was done the same way but was less successful. Bumper looks okay but less happy with the chassis. Even scratching at it and scrubbing with a toothbrush wouldn't chip the paint in some areas. Maybe there was more paint on those bits and it had just set too hard.
                  [ATTACH]362490[/ATTACH]
                  [ATTACH]362491[/ATTACH]
                  Then the rear load bed. This was overcoated in Vallejo and chipped off in (scale relative) big chunks as soon as I went near it. Might look better with some finer sponge chipping to blend it in, but not a pretty sight as it is.
                  [ATTACH]362492[/ATTACH]
                  I'm unlikely to use this effect on the main body now even though it's all undercoated in rust colour. I'll probably use sponge/brush chips over the top instead and save the hairspray for when I've had more practice.
                  To lift my spirits after that setback I painted up some rammle for the back of the farmers vehicle
                  [ATTACH]362493[/ATTACH]
                  Then started blocking in the main colours on the scenery. Very stark of course but it's just a basic background to start from.
                  [ATTACH]362494[/ATTACH]
                  • scottie3158
                    • 14638
                    • Holbeach
                    #69
                    That looks pretty good to me mate
                      • 16310
                      Hi Andy
                      Impressive stuff. Base looks to be working well.
                      As for the hairspray chipping I find it difficult to control and I get inconsistent results. The purpose made chipping fluids available work better. Having said that I have seen great results using hairspray.
                      • minitnkr
                        • 7809
                        • Dayton, OH USA
                        #71
                        I've seen it done in 1/87 scale to good effect, so it can be done. I don't care to know how, so haven't tried it. Modern military finishes are so tough you seldom see chipping except where stuff bangs into it heavily & often, like your front bumper (which looks great BTW) and areas where stones/rocks are thrown into them hard. Wear-thru for sure, but chipping usually only w/damage. Areas like the bed would have more slide type wear than chipping also. The old tractor would likely have brush painted repairs to the finish or actual oxidation causing the finish to peel off the rust beneath due to age, so chipping methods could apply here for sure. Just my tea time ravings. PaulE
                        • Si Benson
                          • 3572
                          #72
                          Hi Andy,
                          Good too see you experimenting with new techniques, Its coming together nicely.
                            Cheers Paul, probably being too hard on myself as usual. Much of it will be disguised by weathering anyway I guess.
                            Thanks Jim, I'm definitely finding it inconsistent. Even different areas on the same part react differently. More practice or dollars needed, lol
                            Paul E, thanks again, your input always gives me something to think about. I'm looking at the two load beds as kind of field additions so probably not as hard wearing as the main body. Will make note of the scratching/sliding damage for sure. Not something I'd thought about but obvious now you mention it!
                            Thanks Si. I like to keep trying new things, got to be the best way to learn.
                              Andy.
                              Loving the base, looks great.I've used drywall adhesive / filler as well. It does take time to dry and needs warmth. I did notice that when painted it can become wet again, but does dry out.
                              Camo looks good, along with the woodgraining.
                                Thanks John.
                                I got a bit impatient with the filler as it still hadn't dried after 3 days. In the end I scraped most of it off, built up the slope with foam instead, and just used a very thin skim on top. Probably how I should have done it in the first place really!
