Gulf War Dio
    [ATTACH]38979.vB[/ATTACH][ATTACH]38980.vB[/ATTACH][ATTACH]38981.vB[/ATTACH][ATTACH]38982.vB[/ATTACH][ATTACH]38983.vB[/ATTACH]Thank you Paul & James, here are some photos of the lolly pop lights I made for the 926A1 5 ton. I will also install a set on the M35A2 most but not all of the early eighty's U.S. cargo trucks carred these lights. regards Glenn
    [ATTACH]42962.IPB[/ATTACH]
    [ATTACH]42963.IPB[/ATTACH]
    [ATTACH]42964.IPB[/ATTACH]
    [ATTACH]42965.IPB[/ATTACH]
    [ATTACH]42966.IPB[/ATTACH]
      • 22851
      #32
      Hi Glenn just ben looking through your thread some great work going on there I realy like the burnt out tank great skills
        [ATTACH]39148.vB[/ATTACH][ATTACH]39149.vB[/ATTACH][ATTACH]39150.vB[/ATTACH][ATTACH]39151.vB[/ATTACH][ATTACH]39152.vB[/ATTACH][ATTACH]39153.vB[/ATTACH][ATTACH]39154.vB[/ATTACH]Thank you Ian, I put down the 1/35th scale models to do some work on a 1/1 scale, model lol. this last week I've been painting a 1944 M4 sherman that going on the dragon wagon, and tuesday the 24th were getting in a M60A3 for restoration enjoy the photos. Regards Glenn
        [ATTACH]43116.IPB[/ATTACH]
        [ATTACH]43117.IPB[/ATTACH]
        [ATTACH]43118.IPB[/ATTACH]
        [ATTACH]43119.IPB[/ATTACH]
        [ATTACH]43120.IPB[/ATTACH]
        [ATTACH]43121.IPB[/ATTACH]
        [ATTACH]43122.IPB[/ATTACH]
          • 22851
          #34
          A nice touch up Glenn. Thanks for the photos
            Thank you Ian, I started on the next in line of the gulf war dio, the 1/35 scale OH-58D Kiowa.Begining with the AN/AVR-2 Infrared Jammer, injoy the photos .regards Glenn
            [ATTACH]43743.IPB[/ATTACH]
            [ATTACH]43744.IPB[/ATTACH]
            [ATTACH]43745.IPB[/ATTACH]
            [ATTACH]43746.IPB[/ATTACH]
            [ATTACH]43747.IPB[/ATTACH]
              Spot On.
              The more I look at that T59 the better it looks,I passed through the Suez Canal back in the seventies not long after it had reopened and there was still a lot of battle damaged machinery about including tanks, from memory you have got it spot on.
              Cheers sharowjohn.
                Thank you John, I'm pleased with the way it turned out, being my first attempt at battle damage since being a small boy with a candle and needle lol, I am however stuck on the OH-58D. I'm trying to simulate the rotors in flight but not having much luck. I've cut out some 1/32nd lexan blades and they are about the right size but I'm not happy with the shading (see photos of OH-58D in flight last post) I'll keep trying sooner or later I'll figure it out. but now I'm off to finnish my 1 to 1 scale M-4 sherman tank. I'm putting on the decals today lol. regards Glenn
                  Excellent work battle damaged Tank looks real class mate some great work here thanks for sharing.
                  Robert
                    Thank you Robert, I still have a long way to go to finishing the dio, Regards Glenn
                      WOW!!!! the damage on the Soviet tank is amazing..... Is that shaped charge damage?? or from a depleted Uranium penetrator from a Sabot?? ALso the IR Jammer..... sis you use the Hasegawa vapor deposition sheets to add that coating to the clear parts???
                        [ATTACH]42640.vB[/ATTACH]Hi Marc, thank you, I was not there when then tank got hit so I don't know what round they used, but they blew hell out of it diden't they LOL, as for the jammer I back painted it crome sliver and cut out 2mm x 2mm squares of iradesent flim and applied them with clear coat. Regards Glenn
                        [ATTACH]45945.IPB[/ATTACH]
