Lead wire
    Lead wire
    Hello
    Can a kind person please tell me where I can get lead wire for simulating cabling etc. I don't see it in John's shop. I assume these come in scales? I'm after 1/72.
    Thanks
  • ojays
    • Oct 2011
    • 1713
    Try here.
    Myself and others on here have used them with some success.
    There is a post a couple of days ago by Scuff about this.
    Gregg
      Aidan Similar to Gregg but Amazon. Just put Lead Wire in the search.
      I also use soldering wire which comes in a variety of widths. Found this easier to handle than the straight lead.
      Think also the Train Model Makers supply little bundles of differing thicknesses.
      • John
        • Mar 2004
        • 4677
        • John
        • Halifax
        I used to sell it but the UK distributor has stopped dealing with plusmodel which is a shame as it was a good seller, I could go direct but I have to spend at least €300 + carriage! that's a lot of lead wire
        A good alternative is electrical fuse wire, a lot cheaper as well
        www.scalemodelshop.co.uk
          Little Cars do it too
            Originally posted by \
            Aidan Similar to Gregg but Amazon. Just put Lead Wire in the search.I also use soldering wire which comes in a variety of widths. Found this easier to handle than the straight lead.
            Thank you
              Thank you
              I used to sell it but the UK distributor has stopped dealing with plusmodel which is a shame as it was a good seller, I could go direct but I have to spend at least €300 + carriage! that's a lot of lead wireA good alternative is electrical fuse wire, a lot cheaper as well
              Thank you
              • aaron
                • Oct 2011
                • 2019
                Fuse wire from the household powerbox
