Super Glues?
    Super Glues?
    This is probably a stupid question and I have searched the archives before posting....
    Would some kind soul please advise me on what superglues do what? IE why different thicknesses. Were I to buy some (and I need to), which ones should I consider. Not from a manufacturer perspective but more from a usage perspective. I'm not interested in gap filing.
    Thanks
  • eddiesolo
    • Jul 2013
    • 11193
    I use Zap thin CA. I like the way it flows and gets into all the nooks-of course down side is that it can run all over the place if not careful.
    Si
    • ojays
      • Oct 2011
      • 1713
      I use thick for gap filling, medium for basic assembly & thin for wicking into very fine or difficult to reach joints.
      But many have their own personal ways of using!
      Gregg
      • monica
        • Oct 2013
        • 15169
        this one is an interesting subject, Aidan,
        I mite even lean some think as well,
        i just use the cheap stuff from the pond shop, 7 tubes for $ 2.50, as most ends up on my finger,
        i find some times it dose not tend to stick,wood to wood so well,so i think they maybe diffidence ones, like a muilt one
        • ojays
          • Oct 2011
          • 1713
          I also use this at times.
          [ATTACH]85132.IPB[/ATTACH]
          I also use activator when I want something to cure immediately!
          Gregg
          • PaulTRose
            • Jun 2013
            • 6821
            • Tattooine
            i almost exclusivly use thick ca for model making......its quick, dont have to wait too long before i can get on with the next step....thin just runs off, thick stays where its put
            another use for ca is making a really hard filler,.....mix a bit of talc with ca
            Per Ardua
            • aaron
              • Oct 2011
              • 2019
              I found a super glue at my local hardware store that has a little brush applicator...perfect considering my local hobby shop told me a brush applicator with super glue would be impossible.
                I use superglues usually when I've already painted the surfaces I want to glue. I use thick or thin in the same way you do for polystyrene cements - thick for major 'structural' jobs, and thin for where you want the glue to wick around a joint. I'd like to use a very fine paint brush to apply the thin stuff (instead of the over-thick brush that comes with the bottle), but can think of no way of cleaning the brush afterwards - does anyone know a secret for this?
                • Alan 45
                  • Nov 2012
                  • 9833
                  I use a gel super glue for PE as it gives you time to position your piece and doesn't dry out so fast
                    I`m like Monica I use the cheap ones from the pound shop, I only do this because I found there wasn`t a great deal between the expensive ones and the cheap ones,I also use the two part epoxy resin, I find these very useful when using resin or white metal kits.
                      Hi Abidan
                      I use Powerdrop. John has the fuLl range in the Shop.
                      Used a number of types but found these the best for me.
                      The range is wide thin medium thick.
                      They also do a fog less type for transparent plastic. Note this takes longer to go off.
                      Also John has little plastic tops to fit on the little bottle. They have a very long spout with a small aperture. On average the glue does not congeal but if so nip off the top..
                      Happy super glueing.
                        I always use Bob Smith industries ultra thin Cyanoacrylate. It has a full water like consistency. It is great for resin kits as they can be used for cappilary action sage and it is also great with PE as it does not "glob" everywhere as it has a thin consistency. It is normally used for repairing RC planes, but it is ideal for PE and resin. I also use the cheap type from supermarkets for more heavy duty type work.
                        • stona
                          • Jul 2008
                          • 9889
                          Something to consider is the size of the bottle/tube you are buying. CA glues do go off once exposed to air. You can delay this by keeping it in a fridge, but getting that past SWMBO can be a daunting task.
                          I tend to use the small bottles/tubes from a local hardware store (they do still exist) when I need to actually glue anything with superglue. For filling (I know you didn't ask about that) I use a medium or thick CA, a decision I make having scientifically eyed up the gap, mixed with talcum powder or baking powder. This is my primary use of CA glues and the brand doesn't seem to make the slightest difference.
                            Well thanks everyone! As always, a host of experience and wisdom, I'll try a thick and a thin I think. Good point about the small bottles thanks Steve. I'll peruse John's store.
