Any IT wizards that can help?
    • 18301
    Hi peeps.
    My computer is throwing a fit again!!!
    It only affects my browsers which is most odd and annoying!!!
    Her is a picture of what it looks like..
    • 18301
    Well there would be if I can figure out how to up load from the gallery!!!!
    damb it!
      Morning Ian
      Any problems with my browser I just uninstall download the most recent and install so far that has worked. Use FireFox which retains settings after uninstalling.
      • monica
        • Oct 2013
        • 15169
        sorry to hear Ian, think try what Laurie,said and just save your bookmarks else were, so you can import again
        as i use firefox as well and has had its moments,
        • Adrian "Marvel" Reynolds
          • Apr 2012
          • 3008
          Have you tried switching it off and on again?
            • 18301
            Have had fire fox before. Never again.
            I will try a reinstall of the browsers and see if that help. I think I have the .exe files I need.
            A bit hard to down load them when I cant see the internet...
              Which browser are you using Ian ? Not Explorer !
                I have same problem, on my comp always not responding (not only for the browsers)
                After formatting disc and re install windows and all programs, now working fine.
                I was try to found solution online but nothing to found.
                So, I solved with fresh re install of all
                I know I didn't help but just to share my expirience with you
                And I'm using Chrome (Firefox is to demanding and slow, IE never used)
                Roman
                • flyjoe180
                  • Jan 2012
                  • 12938
                  • Joe
                  • Earth
                  Do you have a way of restoring the computer to an earlier time Ian? It's called System Restore and is found in Windows under Control Panel>Recovery. It restores your computer to an earlier time and does not affect any documents, music or pictures. You can select a restore point to where you know the system was working.
                  I'd try that before the radical formatting option.
                    • 18301
                    i tried that last night Joe but it did not help. drivers are also up to date...
                      Ian have you tried installing Explorer from your original installing CD ?
                      This will then give a base for downloading your favourite browser.
                        • 18301
                        hmm. good plan Laurie but only one problem. Windows preinstalled and no hard copy. HP at their best.
                        Tried reinstalling the screen drivers in safe mode. that didn't work either..
                        I just wrote 25 pagesin word. watched a video. no problems. Open the browser...bljue scren of death
                        • flyjoe180
                          • Jan 2012
                          • 12938
                          • Joe
                          • Earth
                          Try this Ian:
                          http://www.sevenforums.com/browsers-mail/212433-browsers-not-working-internet-connection-fine.html
                          Or this:
                          http://www.sevenforums.com/browsers-mail/41754-browser-not-working-but-internet-connected.html
                            http://forums.mydigitallife.info/ try this site they are mostly microsoft engineers with problem solving heads
                              • 18301
                              i will have a look at those when i can steal the wifes lap top.cheers
