Anyone experience with AFV Club....
  • BarryW
    • Jul 2011
    • 6139
    I am building my first armour for over 30 years. In the old days I did virtually all Tamiya and some Italiari armour but when I visited Bovington recently was tempted by an AFV Club Centurion V.
    This, of course, is very different from the 32 scale WW2 aircraft I tend to prefer but it is nice to have a change now and again...
    This kit has a lot going for it, a nice metal gun barrel for one thing.... But the engineering is some of the worse I have ever found.
    Take the track rollers. Logic would suggest a line of pins over which you can position the rollers, simple, but not in this kit. There are two rollers to fix together with just a short pin that fits the first roller. The second roller glues to the first in the centre only where the pin would go through if it were a sensible arrnangement. There are some very small location tabs that don't fit and the only way to glue them together securely is to file the pins flat, drill holes into the 16 rollers, fit metal pins and glue. I could not be bothered with that and have just glued them together, not a very secure fit but fingers crossed.... A bonkers bit of engineering. The poor engineering extends elsewhere too, some engine louvres with very vague positioning and nearly none existent location tabs that again need filing off cos they don't fit....
    Is this typical for AFV Club? Its a pity that they cannot just apply a little more though and detail into the engineering.
  • eddiesolo
    • Jul 2013
    • 11193
    Hi Barry, looked into one of their Churchill range, around £45ish, but like you found that, for me, they are a lot of faffing so left alone and moved it on. To me they seem to be for the more serious modeler who likes to pin and drill and faff around. Some superb kits and the quality detail is great, but not sure why the fit is bad. One lad got a track set and he had issues trying to get that to work. Others may have had better experiences with this model maker.
    Si
    • ojays
      • Oct 2011
      • 1713
      Only AFV Club kits I have experience with are 1/35 Flak-Vierling, and 1/35 German Mines Set.
      Both had exceptional detail, and good parts fit.
      The only problem I had was with the mines set (so many minute parts)
      I left several of them off.
      The instructions did live a lot to be desired though.
      Gregg
        • 18302
        I too have only build one AFV kit. Great detail, and the fit was OK. Over engineered? Definitely. There were many things that could have been much simpler and still looked the part and as you point out Barry, the location points could have been better.
        • BarryW
          • Jul 2011
          • 6139
          I dont mind the work as such but at least they could include some sensible engineering. Those rollers and louvres just do not make sense they way they did them.
