Testing thread
Bigger text
bigger
different colours
bold bold italics underlined
https://youtu.be/LSUX5R2B01s?si=lUHYm9PTaQQeIYM0👍 1Comment
Geoffers,
To start your post/comment you will start in this area.....
So, here is my description of the latest build, model arrival, question about something I cannot get my head around.... and on it goes blah! blah!....
I now need to insert/upload my photo(s) with comments.... And so I click on 'Upload Attachments' as you have done, and I need to re-size it so that the Moles among us can see it.
The Upload URL bar scrolls across and once it finishes there is a small image of your chosen object, and to the right is the word 'Insert' and then in Blue are the words Thumbnail, Small, Medium, Large, Fullsize and Remove.
Normally to get an image to fill the area I would choose 'Large' which I have done here.... But notice where the flashing icon is at the bottom right of the image once you move your mouse pointer off the image.... so that is the end of my text I now click the return key (to the right of the @ key) to move the icon to the next line.... and then click on the blue 'Large' word.
And as described the icon is to the bottom right of the photo, I clicked on the return button and that has moved the icon to the next text or image position as here
And all you need to do is repeat the operation described above.
I had to learn how to do this after a frustrating couple of hours trying to adjust and put the text in the right place.
Hope this helps
Mike.
PS do not forget to click 'Post Reply.
👍 1Comment
Hi Joe
first step is to press the "quote icon on each of the posts you want to quote, then press the 'post reply' icon
i hve found that I have to select the quotes before I type any text
Peter👍 1Comment
