Help with 3D Printed Models Please
  • Airborne01
    • Mar 2021
    • 4361
    • Steve
    • Essex
    This may be a 'how long is a piece of string?' type question but here goes: I will soon attempt the German Motorcyclist for one of the GBs; it's a 3D print in a light grey resin and covered in copious amounts of release agent (?). My questions are as follows:
    1. What is the best solvent for removing the release agent? (The fine detail looks very fragile so I think the toothbrush is out!)
    2. Adhesives. Will ordinary CA work or does it need something else?
    3. Fillers. What/which fillers are recommended in the light of experience?
    4. Primers. I use Tamiya primers ordinarily, is this still suitable?
    4. Lastly, are there any other recommendations/pitfalls/tips that will help this anxious novice?
    Thanks in anticipation.
  • Neil Merryweather
    • Dec 2018
    • 5352
    • London
    1. IPA isopropyl alcohol,not Brewdog...
    2. Yes
    3. Any normal filler should be fine
    4. Most likely yes. I use Halfords rattle can with no problems
    5. If the supports are still attached use snips rather than a scalpel. It takes longer but reduces the risk of destroying detail
    Looking forward to this. If you have any problems message me because I have bought the files and I can easily print you a section if necessary
    All the best
    • Neil Merryweather
      • Dec 2018
      • 5352
      • London
      If you have any uncured resin, wipe with IPA and then 20 mins under a UV light should sort it .
      A nail polish dryer (if swmbo has one) or a little UV torch - I have one for curing UV glue.
      • Airborne01
        • Mar 2021
        • 4361
        • Steve
        • Essex
        Thanks for your reply Neil, and for your kind offer of mistake remediation! Greatly appreciated.
        • Gary MacKenzie
          SMF Supporter
          • 1059
          • Gary
          • Forres , Moray , Scotland
          1. are you sure its a 3d print , or is it a resin model cast from a 3d printed master ?
          The reason I ask is that no 3d printed model should have any residue on it when given to someone/bought from someone , but many of the ''cast'' versions do have release agent on them ?
          • Airborne01
            • Mar 2021
            • 4361
            • Steve
            • Essex
            Probably the latter then Gary, i.e a resin cast - Blimey, every day's a school day here! Thanks very much
            • Neil Merryweather
              • Dec 2018
              • 5352
              • London
              I'm pretty sure it's a print. The whole point is that it's way too complicated a model for casting
              Are you posting any pics Steve?
              • Steven000
                • Aug 2018
                • 2947
                • Steven
                • Belgium
                If it is a 3d print then that's sort of disturbing for a commercial product... Make sure you don't touch it with your hands and wash them well if you do. 3d resin in liquid form is a health issue.
                • Steven000
                  • Aug 2018
                  • 2947
                  • Steven
                  • Belgium
                  Click on the ">>" to see the pictures of the parts...
                  That's 3d printed, small piece on the right has still supports attached.
                  • Neil Merryweather
                    • Dec 2018
                    • 5352
                    • London
                    seconded.
                    use disposable gloves
                    • Airborne01
                      • Mar 2021
                      • 4361
                      • Steve
                      • Essex
                      Thanks Gents for your replies; I've been working away again so I apologise for the delayed response - so, it's scarily fragile and complicated and now a health hazard - mmm! Oh well, onwards and upwards! Starting very soon so wish me luck! I will definitely post up progress reports 😎
