I'll see if I can work out how to delete it for you.
Update:
Go to your profile inbox to see messages. As you normally would.
Click on the message to read it. At that point you have the option above the message to delete it.
If you are wanting to delete multiple messages and have a good old-fashioned clear out, you can do that from the main message inbox screen. Select the particular message you wish to delete by clicking the box next to it. Or at the top right you can select all messages instead of ticking each one, then press delete.
Your deleted messages go to 'Trash'. Open that and repeat the process described above. It will ask if you want to permanently delete the selected messages.
Update:
HI JOE many thanks followed your instructions an yes ive now able to delete all my messages
many thanks for your reply much appreaciated
ATB
chrisb
