help
  • meggsy
    • Jun 2011
    • 421
    help
    I've just sprayed a model using plasti-kite aerosol spray instead of waiting till it was completely dry I moved it and guess wot I dropped it so now I've got carpet fluff and its badly marked in places wot can I use to strip the paint off or is it just fit for the bin any advice would be fearfully cheers
  • stona
    • Jul 2008
    • 9889
    I don't know that paint but you need to find a solvent that will shift it. I'd suggest white spirits or methylated spirits to start with. Some acrylics come off nicely with isopropyl alcohol or a DILUTE ammonia solution. If you are really stuck (no pun intended) you can put the model in a freezer bag overnight with a good coating of oven cleaner. This one should be a last resort.
    • meggsy
      • Jun 2011
      • 421
      ye cheers unfortunately ive already used white spirit and it made the model brittle and break-up so it is now consigned too the bin got to try and find a company that does tamiya replacement parts now dont suppose you know of any cheers for the advice anyway much obliged
      • meggsy
        • Jun 2011
        • 421
        stona the paint i used was plasti-kote not kite predictive text for you-regards
        • meggsy
          • Jun 2011
          • 421
            if the paint is acrylic you can use oxi clean to totally strip it off. just put some oxi clean in a bucket (or however big of a container you need) with warm water. let the parts sit for about 5 minutes then run them under warm water to wipe it all off. you're back to the original plastic at that point. i've used that method a couple times now and haven't had any problems.
            but it only works on acrylic paints.
              Plasti-Cote. Yucks. I used that on my second model about Christmas time.
              Still tacky after 4 days. Came to the conclusion it did not like plastic models. Must have a solvent which is not compatible.
              Where did that Hurricane get to yes the bin. So did the Plasti-Cote with a good number of choice phrases. Also kicked the bin. Fury has no limits !
              Great lesson use the manufacturer of the paint you are using for all coats to be applied.
