Canopy Glue - What do you use?
    Hi,
    I popped out today to pick up some clear PVA glue to attach the canopy glass onto the Spitfire. I thought great, it'll dry clear and easy to use.
    So I applied the PVA and held the canopies in place for a few hours with some Tamiya tape. Whilst very carefully removing the tape the canopies virtually fell off!
    I made sure the PVA was dry and was also gluing directly to the plastic as well.
    So, what do you guys use to attach your glasswork?
    I've been looking at Microscale Crystal Clear and Humbrol Clearfix online tonight. Any preference between these, any pitfalls? Do they cause the clear perspex to frost or melt if used too heavily and most importantly.... are they strong enough to hold my canopy on.
    Thanks,
    Colin.
  • AlanG
    • 6296
    I use Microscale Kristal Klear and Gator's Grip Acrylic glues. They don't cause fogging of the clear parts at all
    • stona
      • Jul 2008
      • 9889
      Exactly the same here.
      I've used Clearfix as well in the past,they all work fine. I used to have a tube of the glue watchmakers use for fixing glasses which was very strong but it seems to have dematerialised so I can't tell you what it was called!
      Found it! It's called GS Hypo Cement. The good thing is that it dries fast,about ten minutes.
      • Dave W
        • Jan 2011
        • 4713
        I use clearfix and crystal clear.Crystal clear is better at filling gaps in poorly fitting canopies.So you dont get paint from your airbrush through to the inside of the canopies.
          I use standard superglue, decant a puddle to a piece of paper, then with an old needle in a pin vice I touch drops to the part of the canopy that touches the frame, just a few tiny drops and provided the fit is good it'll grab and stick like, well, like sticky stuff Because you're only using tiny drops little chance of fogging, i've not fogged one canopy yet with this method, like you I discovered PVA didn't work well for me
            Thanks for the info. guys.
            I think I'll try the Microscale Krystal Klear but I'm interested in that watch repairers glue.
            Atb,
            Colin
              Change of plan, went for the GS Hypo Cement.
              That looks like a precise applicator and an easy glue to use, even cleans off with IPA if you manage to spill it.
              Thanks for the heads up Steve (Stona).
              • tr1ckey66
                • Mar 2009
                • 3592
                Cooperman
                I use this stuff - it's pretty good. Be careful though as capillary action causes the stuff to continually come out of the hypodermic nozzle.
                Paul
                  I use krystal klear for all clear parts, and to hold small parts to cocktail sticks for painting
                    • 18286
                    Another Krystal Klear user. I like it for all of the above and that its a water clean up. So absolutely no risk of paint damage.
                    You can also you Johnsson Klear but not so good for filling gaps.
                      I've always used formula 560 canopy glue, I'll have to try this Krystal Klear of which you speak
                        Just as a follow up, I received some GS Hypo Cement in the post today and just used it..... it's great stuff!!
                        So easy and precise to apply.
                        Thanks for the advice Steve (Stona).
                          Odorless(foam safe)thick Ca glue has worked real well for me and it wo'nt fog the canopy
                            Another thanks Steve. Got my GS Hypo Cement yesterday.
                            Nice thing is that it has such a precise yet simple system of applying the glue. Particularly good for fixing small port hole windows where precision is essential.
                              Hi I wish I had come across this site/forum before today as yesterday I made a mess of fitting my windows into my Beaver model with epoxy, most times when I have used it to fit windows I do a decent enough job but yesterday I made a mess of it when I ended up dropping one of the windows and had to try and recover it from the inside and ended up with the epoxy all over the window and I doubt it will come off so its either leave it a mess or have a go at vacuum forming a couple of new ones which I have done in the past just using a hot air gun and a soft brush (I don't have the room for a vacuum forming machine) and the past attempts normally come out ok.
                              Regards Poppy Ann.
