As most people look in here to see whats happening a quick heads up.
The section for trains has had a bit of a lift. In short there are now sections for trains and rolling stock, under construction, and completed.
Also under Layouts they have also been split to Under construction and completed. There is a new bit as well. Buildings.
Here you can post your treads on the buildings you are, erm, building and a place to show them off before you plonk them into the layout.
Houses, factories, bridges tunnels, all that kind of stuff.
Pop over and have a look.
If you have a tread in there, feel free to move it (if you can) to the most relevant section. If you can not move it send me a quick PM with a link and I will move them for you. Also if you have things hidden away in that junk heap called Other models that you think should be moved to one of these sections.
