Help required
    Help required
    Have any of you good folks got any experience with the Verlinden range more specifically their engine compartments? I am having trouble getting this one to fit and the destruction's are about as much use as a chocolate tea pot. I have thought about cutting the housings out for the running gear stubs but I don't think even that will give enough room. It says it is for Tamiya or Dragon so in theory should go Right?
    I know from past experience that these resin addons can be a sod to work with but this one has me scratching the old nogging. Any help/suggestions will be gratefully received thanks in advance.
    Here are a few pics of my dilemma
  • monica
    • Oct 2013
    • 15169
    did have a bit of a look online for you,Terry,
    and fund this maybe of some help, 9_9 :S
      Thanks Monica that looks a better fit than mine. it also looks like he may have removed the rear plate from the hull and used the engine bay one. Either that or he has sanded the rear wall down to paper depth. this one seems to sit a lot lower than mine so I am thinking I was right about removing the running gear housings which is going to be a bugger to do.
      • eddiesolo
        • Jul 2013
        • 11193
        Can you not skim the bottom of the engine etc so that sits lower, got to be easier than cutting the plate or hull parts.
        • monica
          • Oct 2013
          • 15169
          so glad its of some use to you Terry,and was able to helpout a little,
          I like the sounds of Si,plan to shave some oof the bottom of,the engine,is by far less work,and easier 9_9
            Si looking at it I may have to do both skimming the bottom plate off the resin and remove the running gear housings to drop it enough
            [ATTACH]262751.IPB[/ATTACH]
            The gap in the above picture is with the upper body part sat on top of the bulkhead plate to get rid of that gap is going to take a bit of chopping. If it doesn't work I can I will just use the engine parts in the barn.
            • monica
              • Oct 2013
              • 15169
              oh ouch,that would be good to 10mm or so, :S
              but the engine may have a lot off,what you call it extra mold,on it as well,so its suitable for a few models, 9_9
              so the death may be able to be trimmed back,
              • eddiesolo
                • Jul 2013
                • 11193
                That is some gap Terry, if you feel confident then hack away. A lot of work for very little return in my book.
                  • 18286
                  If you read the article Terry he explains how he did it.. I found the "interesting stuff here: http://www.hello-napalm.com/scaleMod...s/panzer-2.php This is where he explains it. You're going to have to cut something. Hopefully not your fingers.
                    Thanks Ian for that Ian it has helped a whole lot and made things a good bit clearer.
                    • stona
                      • Jul 2008
                      • 9889
                      Not much help to you, but though Verlinden (which is on the point of closing or has just closed for the final time) were early in on the resin after market, they never once made a set that didn't need a good fettle to actually fit the intended model.
                        Thanks for that Steve thats's made me feel a whole lot better about the fit issue
                        • stona
                          • Jul 2008
                          • 9889
                          It's certainly nothing that you have done
                          You are just one of the many who will end up filing plastic until you can see through it, and hacking at bits of resin, to make it all fit.
                            Don't I know >
                              Thanks all for your input it was much appreciated the end result can be seen here http://www.scale-models.co.uk/topic/...comment-333777
