Clean or not clean?
  • John
    • Mar 2004
    • 4700
    • John
    • Halifax
    Clean or not clean?
    just out of curiosity do you clean your sprues before painting or just crack on with it.
    www.scalemodelshop.co.uk
    • 22983
    There's been too many times when I've put paint on and its pooled up on me. But then I don't always buy top end kits.
    • PaulTRose
      • Jun 2013
      • 7252
      • Tattooine
      erm......need a third option of 'sometimes'
      i try to but often i just forget so its probably 50/50
      Per Ardua
      • R_G
        • Feb 2015
        • 54
        I clean the parts after they are assembled/sub-assembled right before I start priming and painting. A quick cleaning with 90% rubbing alcohol is usually sufficient.
        Ralph
        • dave
          • Nov 2012
          • 1844
          • Brussels
          I very rarely clean sprues, unless I am dealing with Resin in which case I clean with vengeance.
          I have had almost no problems with paint on plastic, but I have had some really bad experiences with paint not sticking to resin even after washing.
            If I have a large surface area, then sometimes I may use my AB and spray with Iso. Another point I will mention, is that every time I go to work on a kit I always wash my hands first to remove grease from them.
            • peterairfix
              • Jul 2012
              • 11172
              I do on the odd occasion but its very rare that I do
              • zuludog
                • Mar 2015
                • 239
                For years I never cleaned the sprues & component parts, but that was when almost all my paints were Humbrol enamels, and they stuck & covered very well
                As a returnee I still use enamels, many of them years old, but some of the other brands I have purchased recently are thinner, as are the current Humbrol enamels, and I have also acquired a few acrylics. Although I haven't experienced any pooling or non - adherence, some of them don't seem to cover very well, so I have started washing my sprues
                I have two shallow plastic trays, one containing water + a few drops of washing up liquid; and one plain water. Fairly obviously I wash in the soapy water first then rinse; sort of swish it about and also use a soft brush, actually a make-up brush begged from my daughter
                If there has been a lot of filling & sanding I carefully wash/brush in a similar manner
                Then I spread them out on kitchen towel or a soft tea towel to dry overnight
                I suppose I could use a mixture of meths & water for the rinse, and keep it in a jar for the next time
                I only do brush painting
                • james pithouse
                  • Dec 2014
                  • 1295
                  I never clean the spruce, that's part of being a model maker it proves your doing it right plus, if you drop the part you have painted it's easier to pick it up again without touching the part you have painted
                    • 18302
                    Depends on the kit, if there is a lot of release agent I will, otherwise it's a quick wipe with IPA
                    • Mr Bowcat
                      SMF Supporter
                      • Dec 2016
                      • 4716
                      • Bob
                      • London
                      Nope.
                      Si vis pacem, para bellum.
                      • PaulTRose
                        • Jun 2013
                        • 7252
                        • Tattooine
                        ditto
                        Per Ardua
                          Never.....
                          • John
                            • Mar 2004
                            • 4700
                            • John
                            • Halifax
                            When I first stared this forum quite often other members would always say to clean first if someone had issues with painting, it looks like it’s not the case anymore.
                            • BarryW
                              • Jul 2011
                              • 6142
                              Only wipe with ipa over the main airframe before painting. I don't bother with small details or the interiors.
