The next model I am doing calls for 075 - 1kg to weigh it down, what is the best material to use?
Weighing down models
GuestTags: None
Led pellets in small fabric bags should be the best option I can think of unless you can make led bits that can be glued in place?
But like Graham said 1 kg is an awful lot of weight! That's two pints!Comment
Thanks for the replies, I'll get a bag. It's to weigh down the 1/32 ships catapult. It goes into the base which is about 12cm x 12cm x 4cm.Comment
