Filler help
  • Peej
    • Aug 2014
    • 919
    Filler help
    On my current build I have a gap that needs to be filled. Is there a filler I can use that will not need sanding as it will not be possible to do so with were the gap is? Thanking you in advance.
  • Mr Bowcat
    SMF Supporter
    • Dec 2016
    • 4715
    • Bob
    • London
    I use Vallejo filler and tend to run a wet fingertip over it which removes excess and leaves a smooth finish.
    Si vis pacem, para bellum.
    • rickoshea52
      • Dec 2011
      • 4081
      • Rick
      Deluxe materials plastic magic filler is good. A wipe with a moist cotton bud before it dries avoids the need for sanding.
        I mix Tamiya white putty with Tamiya extra thin cement and let the capillary action draw in the putty.
        Usually doesn't require sanding, but if I have to use putty/filler on a sensitive place I use Milliput and run a wet finger over it and then let it dry. No sanding required!
          I'm with Bob, and if you can't get a finger in there, a damp and well compressed cotton bud works well.
          • colin m
            • 9064
            • Colin
            • Stafford, UK
            and so do I, or a wet cotton bud.
