Decal Paper help Please
  • Adrian "Marvel" Reynolds
    • Apr 2012
    • 3008
    Hi all,
    I was just wondering how people use this, I'm asking as I tried it a while ago but after a few months the decals I had made came off. I know I should have used a coat of something over the model but didn't bother.
    So what do you use to fix the decal onto the model if I don't want to lacquer it after?
    Adrian
  • PaulTRose
    • Jun 2013
    • 7251
    • Tattooine
    print with an inkjet printer
    spray over with an acrylic varnish
    cut out and use like any normal decal
    Per Ardua
      • Apr 2012
      • 3008
      See I know how to use em and did as you say, but after a couple of months they dropped off, I don't want to varnish the model so need to know if theres something I can fix em on with
      • PaulTRose
        • Jun 2013
        • 7251
        • Tattooine
        been a long time since i used decal paper but ive never had a problem.......are you putting them on a shiney surface?......wont take on a matt surface
        Per Ardua
          • Apr 2012
          • 3008
          Its a satin surface, would it work if I used a thin amount of the decal film liquid on the hull then applied the decals?
          • monica
            • Oct 2013
            • 15169
            I had some think much like that happen,with old decal,and use a flat varnish ,pushed bach down the decal,
            then just about dry,a couple of thing coats over the top,
