Trumpeter 1/16 t34/85 model 1944 factory no.183
    Hi All,
    Ive managed to acquire this model for a fantastic price. I have a question for everyone. Because it is a very large and detailed model i am wondering what paints would be best to use. I already spray with modelair, i also use revell acrylics , would the revells be good enough to use and if not what paints would anyone recommend.
    Thanks for any help.
    Si
    • 18302
    I would just use what I normally use. Just because the kit is bigger, the only real difference is you will need more of them...
    Use what you are used to and every thing will be fine.
    How about a picture or two of that massive tank then?
      thanks for the advice.i was just wondering whether the revell were good enough in a way. ill post the pics when ive done it. im a bit chicken to start. making a chinook at moment. might make the t34 my xmas build.
      si
        dont know if it helps but i have just found out that revell acrylics work perfectly in an airbrush with tamiya acrylic thinners as well as their own thinners which i have had trouble getting hold of in my local model shops.
