Our planning authority has just approved this application to convert a WW! German bunker - a personnel shelter to be exact - into a one bedroom house.
This first photo shows the bunker's position: as a personnel shelter up to 14 soldiers could live in it, they would have crewed the bunkers across the road from it. Two of which you can see in the photo below.
[ATTACH]314062[/ATTACH]
Under the plans, the reinforced concrete walls that flank the bunker will be retained, but the existing wall at the rear will be demolished and a new blockwork wall built. The extension will house the lounge and kitchen/diner. The foliage on the north, south and west sides of the structure will be retained. Inside the bunker a bedroom, en-suite and utility room will be created, with two sun tunnels to get light into the bedroom.
This is an artist's impression of the finished build:
[ATTACH]314059[/ATTACH]
It is a while since I was around that particular bunkers but here is a plan of a similar one:
[ATTACH]314061[/ATTACH]
It was built to full Fortress standard so the roof will be at least one mtr thick so good luck to whoever is drilling holes in it for the light pipes. At least the bedroom will be well soundproofed. This is going to be one building site worth keeping an eye on.
Peter
Peter
