My sword is bent!
    My sword is bent!
    Hi everyone.
    Just got the Highland Officer out of his box to start trimming the parts, to discover the sword is bent. It's a resin figure and the curve isn't too bad, but still needs straightening.
    Any suggestions?
    Thanks
    DS
  • Mr Bowcat
    • Dec 2016
    • 4661
    • Bob
    • London
    Soak in hot water, should soften it enough to straighten. I'd probably clamp it to something straight as it cools.
    Si vis pacem, para bellum.
      Thanks
        I tend to hold bent swords (etc!) over the steam from a kettle.
          A hair dryer works well to soften resin for bending — less messy than hot water, provided you’re careful where you point it
            So, I assume the resin could melt if it's overdone?
              Yes Dave - take it easy.
                lol ha, just don't do what I did earlier in my modeling days: hold a lighter under it! :surprised: bad things happen..
                • Mr Bowcat
                  • Dec 2016
                  • 4661
                  • Bob
                  • London
                  It's why I suggested hot water, you can soak it until it's pliable enough to straighten, without the risk of overheating and ruining the piece.
                    ...and have a piece of white metal ready to glue onto the hilt if all goes t1ts-up.
                      Not normally, but it can burn if you do like @HerrElektrika did
                      • rtfoe
                        • 9202
                        • Richard
                        • Shah Alam, Malaysia
                        Dave...the sword in those days were specially for cutting round corners...I'll get my coat. :smiling4:
                        I would clamp it straight first then insert in hot water then let it cool with the clamp still on.
                          This is why I like white metal! You can just bend it back into shape if it has a dog-leg.
