Windows 10 help
    Windows 10 help
    Hi all,
    After reading a couple of comments in posts on them forum I'm hoping somebody will be able to solve my problem..
    I've just backed up my files containing all my music ref photos etc and have done a complete reinstall.. Three days later.. I've gone to access my back up drive and it won't give me access to these files, can anyone help me out and point me in the right direction to gain access please.
    In anticipation..
    Regards
    Brad
  • bilbo
    • May 2018
    • 123
    Is there any kind of error message?
      Hi Dom,
      I have this...
      [ATTACH=CONFIG]n[/ATTACH]
      • Gary MacKenzie
        SMF Supporter
        • 1059
        • Gary
        • Forres , Moray , Scotland
        open file manager
        change to drive f: and select the folder mentioned above.
        right click on the folder
        select ''give access to''
        select specific people
        find yourself or all users
        give read write access from dropdown ( select name from list , click down arrow , set read/write )
          hi Dom,
          thanks for quick replies...it's coming up as your file can't be shared?
          • Gary MacKenzie
            SMF Supporter
            • 1059
            • Gary
            let me have a mess around with my machine in morning , and i'll see if i can work out why you cant alter.
            What did you use to backup the files , did you just copy them to f: or use a backup program ?
              Bear with me Dom , things could be happening, it was win 10 back up to a spare hard drive .I'll give update tomorrow also.. Cheers have a good one
              • Gary MacKenzie
                SMF Supporter
                • 1059
                • Gary
                If windows 10 backup , relaunch it and do a restore , then files should be available.
                May need to select the restore "select another back-up" and point at backup directory
                  Did you have any luck? The other thing is to make sure you are logged in with administrator privileges, see the bottom section of this
                  Change a local user account to an administrator account
                  Learn how to add user accounts in Windows 10 and Windows 11. With an account, each person has separate files, browser favorites, and a private desktop.
                    Thanks all, no good , shortly afterward I got the blue screen of death.. reinstall again tonight if possible. Another three days of installing and updates etc.. Nightmare..
                    So I'll probably have to come back to this shortly.. Thanks to all in the meantime....
                      New install done...only 4.5 hours.. That's it now till tomorrow, sure the updates will kick in soon, then we'll see if can get my backup stuff back.
                        [ATTACH]335174[/ATTACH]
                        Hi Gary and Jimmy
                        Haven't forgot about your advice, will try the above at the weekend and let you know.
                        Cheers again.
                        • boatman
                          • Nov 2018
                          • 14591
                          • christopher
                          • NORFOLK UK
                          Hi Brad I symphise with what happen on this windows 10 im finding it difficult as well it not a patch on vista
                          chris
                            You can quickly check if you're using a temporary profile using these steps:
                            1. Open Settings.
                            2. Click on Accounts.
                            3. Click on Sync your settings.
                            4. If you see a message at the top that reads: "You are logged on with a temporary profile. Roaming options are currently unavailable," then reboot your computer.
                              Note: It may take a few reboots until you see your account on the sign-in screen.
                            5. Sign in with your account.
                            Once you've completed the steps, the temporary account should go away, and you should now be able to access your documents, pictures, and videos from your original account.
                            Or try this.
                            Try taking ownership of the files and folders on the drive:
                            To take ownership of a file or folder
                            Open Windows Explorer, and then locate the file or folder you want to take ownership of.
                            Right-click the file or folder, click Properties, and then click the Security tab.
                            Click Advanced, and then click the Owner tab.
                            Click Edit, and then do one of the following:
                            To change the owner to a user or group that is not listed, click Other users and groups and, in Enter the object name to select (examples), type the name of the user or group, and then click OK.
                            To change the owner to a user or group that is listed, in the Change owner to box, click the new owner.
                            (Optional) To change the owner of all subcontainers and objects within the tree, select the Replace owner on subcontainers and objects check box.
                            Mike.
