What varnish to use....
  • Peej
    • Aug 2014
    • 919
    I am part way of putting the decals on my 1/32 Mosquito and I have decided to give it a coat of matt varnish to finish it off. What would you guys suggest as I have never done this. I will probably be airbrushing so a non/low odour would be preferable. Thanks in advance.
    Paul
    Paul . the best mat varnish I ve found is by AK, ULTRA MATTE. I wanted one that was matt, and this fitted the bill .
    I would advise really shaking before use, mine is a little old now so I add some flow improver and a touch of thinners. All so use a fairly big needle and have a practice first. It does give a good finish.
    Hope this is of some help.
    • Peej
      • Aug 2014
      • 919
      Thanks John.
      • stillp
        • 8308
        • Pete
        • Rugby
        I use Winsor & Newton Galeria matt, from The Range at £8 for a biggish (250ml?) bottle. Sprays fine straight from the bottle through a 0.2mm needle at 15 - 20 psi.
        • Mr Bowcat
          SMF Supporter
          • Dec 2016
          • 4715
          • Bob
          • London
          +1 for W&N Galeria. I use both the gloss and the matt after having tried lots of other makes, and find it works the best for me.
          Si vis pacem, para bellum.
          • AlanG
            • 6296
            I use Vallejo Matt and Hannants Matt varnishes. Find they are everything i'll ever need
              I haven't used many but I've found Vallejo to do everything I need too. It takes a couple of days to really harden up and lose that soft, almost suede like feeling, but after that it seems fine.
              • Peej
                • Aug 2014
                • 919
                Thanks everyone. Got plenty to go at.
                  • 19129
                  Just one more....I’ve had great results with Tamiya Matt varnish diluted with Mr Colour levelling thinner and applied with an airbrush.....nicely Matt finish and no frosting at all.....
                    Vallejo is the best matt varnish I have come across.
                    But not the acrylic as popular but the Acrylic Polyurethene. This gives
                    a much better finish than the just acrylic.
                      Careful with a Tamiya if over a water based acrylic as it will it will soften the water based acrylic.
                      How do I know that.
                        • 19129
                        Hi Laurie
                        Had that with Testors but never with Tamiya. Might be because I use Mr color thinner rather than Tamiya thinner.......
                          Hi Tim
                          I used Tamiya semi gloss over a touch up in Vallejo a few weeks back. It
                          just crucified the Vallejo but left obviously the Tamiya in place. But I
                          do use Tamiya 20a thinners to thin about 25%.
                          Also as this had been a touch up it may not have had more than a few days to cure.
                          Have a rule, after reading so many disasters the same Manufacturer over the same
                          manufacturer.
                            Should have added. Water based products over laquer type OK.
                            Vice versa disaster darling.
                            • Peej
                              • Aug 2014
                              • 919
                              I gave it a coat of klear before adding the decals, should I give it another coat of klear before varnishing?
