SUPERGLUED MY FINGERS.
    I think that everyone who has used CA has their own disaster story!
    Wearing glasses has saved my sight on several occasions - metal shards from a shaper, chipping my glasses from about 3m. Myself and two coworkers having our faces sprayed with carbon solvent from a burst pipe above us - I had slight chemical burns to my forehead & cheeks - but my two companions ended up in hospital, having their eyeballs syringed...................
    • stillp
      • 8308
      • Pete
      • Rugby
      #17
      Ouch!
        Tut tut Si you should know better at your age.
        I use 5ml. tattoo cups in a stand. Decant a small amount into the cup. Then I also
        use 3m size tattoo needles to place the C/A.
        All on Ebay & Amazon. All items cheap as chips. Cups dispose of after one use.
        Tattoo needles last a good few times. Use a lighter to burn off old C/A.
        OnUse Rocket in thin meduim & thick. Remove the tops & replace with the plastic
        tube tips. Does not dry out & is less dangerous in decanting. Or finger glueing.
        Just shows how good C/A is with a little dampness. Another tip i have found. Do
        not use accelerator it is messy. Use on one of the surfaces a C/A primer. shorter
        time for going off but enough time for slight adjustments.
