How do I build tree's?
    Hey, I'm making a massive diorama (2.5 metres x 1 metre), and I need to build 3 or 4 forestry blocks, so I will need about 60 trees. I was wondering, how can I make them at 1/72 scale? I would prefer it if they were pine trees, such as those found in Sennybridge, if you've been there.
  • AlanG
    • 6296
    What type of trees you wanting? Fir or deciduous?
      • 18295
      A good cheap way is turn to nature. Does your mum have a butterfly bush in the garden? The flower heads have just the right shape and once they have died back you have just to cut the now dead flowers off, spray them with a spray type glue and then roll them in some of the static grass stuff you can my for model railway landscapes. Works in just about any scale as you can cut the flower heads down to size.
      • AlanG
        • 6296
        Cheapo pipe cleaners also work. If you need to add leave then get some old used tea bags. Dry the contents out then dye whatever colour you require, Glue the pipe cleaners and sprinkle on the coloured tea leaves
        • geegad
          • Mar 2010
          • 2329
          i use wire phone or any wire you can get your hands on you can make it as thick or as thin as you like with as many branches as you want as well
            Ok thanks, I was thinking of the using branches and dipping them in the grassy stuff. I tried it last night on some random branches I trimmed and painted the ends in PVA and dipping them. It looked brilliant, but I just need some proper shaped branches.
            • AlanG
              • 6296
              As John says above. Old electrical cables are very good for making trees. But you're going to need alot of them so this way would be very time consuming imho
                I need about 60-70. Just wondering, how much is the grassy stuff for dioramas, where can I get it, and how much would I need to about 2.5 meters by 1 metre
                  Have a look on here- **** Treemendus Models - HOME**** i seen these at the National and was very impressed. i also like to have a nose om here www.ecscenics.co.uk
                    Don't know if anyone's mentioned seafoam, it's very good, quick and comparatively cheap
                    http://www.greatescapegames.co.uk/documents/Web%20Downloads/tree%20making%20guide.pdf
                    • AlanG
                      • 6296
                      Excellent link Andy
                      • yambam26
                        • Mar 2011
                        • 622
                        Well i remember looking into this awhile back out of curiosity and well found this
                        Its certainly a quick way to make trees!
                        en.
                        • AlanG
                          • 6296
                          Now that really is good and quick Ben. Like it
                          • geegad
                            • Mar 2010
                            • 2329
                            Nice find I thinks I be using that soon
                            A few things around the house will be losing there flex cord
                            Geegad
                              Get some of those old wire bottle cleaning brushes, in the pound shop and shape the bristles to the way you want them. Or take a length of wire fold it in half and put one end in a vice and the other in the chuck of an electric drill, now add lengths of thin fishing line in between the two halves of wire, once done slowly turn the drill on so that it twists the wire and when done cut to shape.
                              scott
