NOISEY MOTORGEARBOX
  • spanner570
    • 15599
    #16
    Originally posted by boatman
    .......but did your waterpump motor have a tendancy to get to hot as its covered in ? as that's my worry with this motor an I don't wanit to catch fire an thanks Ron for your input
    chris
    Over heating might be a problem for your application. My water pump is only on for enough time to fill a kettle!
    Perhaps still worth a punt for the time it would take to trial the idea.
    • boatman
      • Nov 2018
      • 14591
      • christopher
      • NORFOLK UK
      #17
      Originally posted by Mr Bowcat
      Polystyrene should work fine, I expect weight wise there will be little difference between that and foam. You could also try EVA foam which is lightweight, waterproof and available in various thicknesses - https://www.amazon.co.uk/Thickness-Cosplay-Project-DIY(9-6-pieces/dp/B07D4D96WK
      CHEERS Bob for that i'll have a look
      chris
      • boatman
        • Nov 2018
        • 14591
        • christopher
        • NORFOLK UK
        #18
        OK Ron an thanks for your in put as well an yes this motor will be running for hrs as that's what I thought about overheatin an I cant drill some coolin holes in as that will let the sound out only thing I can do is run it for short periods BUT CHEERS GUYS FOR YOUR THOUGHTS all best to you all
        chris
          • 19130
          Cooling holes may work Chris. You need to reduce vibration transmission and overall noise amplification rather than noise per se. Another cooling option is a PC fan pushing fresh air through the area. They are very quiet in operation.
          • boatman
            • Nov 2018
            • 14591
            • christopher
            • NORFOLK UK
            #20
            Cooling holes may work Chris. You need to reduce vibration transmission overall noise amplification rather than noise per se. Another cooling option is a PC fan pushing fresh air through the area. They are very quiet in operation.
            THANKS Tim for that idea but I wont have enough room for a coolin fan an yes I know they come in a small size but i'll have a think about that as I havnt made the sound box up yet but my missus said that when I cover it in with the hanger roof an such it maybe ok an I hadn't thought of that I think at the moment im at that stage of cant see the tree for the woods sayin so time for tiffin
            all best to you stay safe
            chris
            • spanner570
              • 15599
              #21
              Chris.
              How about putting some polystyrene sheet on the underside of the roof too, and anywhere around the hanger etc. that won't be seen. Every little helps
              • boatman
                • Nov 2018
                • 14591
                • christopher
                • NORFOLK UK
                #22
                Chris.
                HI Ron yea that was your idea an a good one an that's what I plan to do but first I got to get some brilliant idea
                all best stay safe
                chris
