Transporting models
What I've used for transport is the following (part built model just for example):
The cardboard rings I got for nothing from a local supermarket - the height is enough to allow the undercarriage to not touch the
base and the cover keeps it in place. You could make a frame for the tomcat out of card in a similar way so the wings support the weight.
I like that Mark...I may be able to fashion something similarWhat I've used for transport is the following (part built model just for example):
Ha no problem Paul...at first glance I though it was an example of what not to do!Comment
Yep, that’s exactly what I meant: put the model on the foam and out some cocktail sticks or something tight up against it. However, I’d advise cutting the foam to fit the container, so it can’t move around and bang the model into the sides. Especially with the pitot tube in the lower photo, I’d expect that to not survive otherwise.Comment
Limited amount of foam...but it is wedged lengthways, so won't be moving anywhereYep, that’s exactly what I meant: put the model on the foam and out some cocktail sticks or something tight up against it. However, I’d advise cutting the foam to fit the container, so it can’t move around and bang the model into the sides. Especially with the pitot tube in the lower photo, I’d expect that to not survive otherwise.Comment
