Alternatives to super glue.
  • peterairfix
    • Jul 2012
    • 11138
    I have developed an allergic reaction to super glue as if I use any brand I will spend the next couple of days sneezing and a running nose so anything with PE is off the build list for a while.
    Any help would be most grateful.
    • 19103
    Two part epoxy will work more effectively, but not as quickly as you will only be able to glue up a few joints at a time.....when doing this I use blu tac to hold parts in place while the glue dries. The other option is soldering, but that only works metal to metal Last option, use PPE. A mask that’s good enough for spray painting solvents should keep out isocyanates.
      5 minute epoxy? - a bit messy, and you always make too much! I have heard that Gorilla Glue is pretty versatile, but I don't think you'll get any alternative with the speed of CA
      • peterairfix
        • Jul 2012
        • 11138
        Thanks I will try the mask option.
          • 19103
          Hi pete
          bear in mind that you’ll need something that keeps our organic vapours and gases, not just particulates.
          • Gary MacKenzie
            SMF Supporter
            • 1059
            • Gary
            • Forres , Moray , Scotland
            I saw a statement that Steve Zaloga uses kneadatite epoxy ( green stuff ) for etch to plastic.
            I have used
            Tamiya Cement
            Tamiya Extra Thin
            Pattex SuperGlue ( Lidl )
            Micro Kristal Klear
            All work to different levels of attachment.
            A newer one to me is Gator Grip glue , getting some positive comments on webboards.
            John did have a link on his site , but it's empty at preent.
            • AlanG
              • 6296
              As others have said above. Gator's Grip glue works. I use it when i want a little time to move the PE around or sticking PE to clear parts (canopies)
                I've used the Gator glue with reasonable result, seems ok, at least it doesn't smell.
                  • 18301
                  Another vote for the Gator Grip glue. But a heads up: there is a gator glue that is used for wood work and is an expanding polyurethane glue. Not the glue you need (all though excellent for wood work :-) )
                  So Gator GRIP. its a PVA glue that grabs quick and sticks like..... well you know.
                  • yak face
                    • Jun 2009
                    • 14236
                    • Tony
                    Another vote for gators grip , I find it excellent and it gives a strong bond when cured , only problem is it’s quite hard to find and can be expensive .
                    • Jon Heptonstall
                      • 1705
                      I've bought a tube of UHU to try with photo etch.A tiny dab to position the bits and add a teeny bit of ca. later if needed.
                      Jon.
                      • stillp
                        • 8276
                        • Pete
                        • Rugby
                        Gator's Grip, or Gorilla Glue Clear, not the ordinary Gorilla Glue as that expands and foams as it cures.
                        • Del640
                          • May 2020
                          • 1214
                          Peter,
                          Although I don't suffer from any reaction with superglues, family members do... I was recommended Gorilla Gel...odourless and user friendly.... Doesn't affect anyone in my home.
                          Del
