What kind of hinges are these? Sorted.
Barrel Hinge or Concealed Hinge.
Looking for the ones used in dolls houses or jewellery box manufacture , will post link when found
smallest i can find so far @ https://www.ebay.co.uk/itm/Hardware-.../323375983041? -
Thanks for the info Gary. Like you, the smallest I could find were about 5mm diameter. I had a thunk about it and I've got hold of some small electrical wire connectors with a ring on the end. I reckon I can make a rivet of some sort to join two of them together to create a hinge. I'll let you know how I get on, but thanks for looking for me.Barrel Hinge or Concealed Hinge.
smallest i can find so far @ https://www.ebay.co.uk/itm/Hardware-.../323375983041?Comment
Do they have to be the round type? RC guys use flat hinges they glue into slots.
They also use these at 2.5mm which is the smallest I can find.Comment
From the given sizes these are 2.5mm wide (I assume this is basically the the length of the pivot) and the width of the hinge piece is 10mm. I'm not concerned about the length as I could always cut them to fit, but my maximum width is only 6mm. I will have a mooch around and see if I can find any smaller ones though. Thanks Karl.Do they have to be the round type? RC guys use flat hinges they glue into slots.
When you look through the pictures you see some at a different angle, don't know where the 10mm comes from but it certainly doesn't look 10mm.....From the given sizes these are 2.5mm wide (I assume this is basically the the length of the pivot) and the width of the hinge piece is 10mm. I'm not concerned about the length as I could always cut them to fit, but my maximum width is only 6mm. I will have a mooch around and see if I can find any smaller ones though. Thanks Karl.Comment
I see your point Karl. I only read the size description but you're right, they don't look 10mm wide. I'll get in touch and see if I can find the actual size.Comment
