Wearable magnifiers...
  • Peej
    • Aug 2014
    • 919
    I have been looking into getting a magnifier. I want one that is on a headband, not too bothered about a light as the light on my bench is good. The problem is I wear glasses all the time and I have been reading conflicting reviews on line, someone saying they are fine with glasses then someone saying they aren't any good if you wear glasses. I was just wondering if anyone here uses this type of magnifier and wears glasses. Price is also important to me as funds are slightly limited. Thanks in advance.
    Paul.
  • Peter Gillson
    • 2594
    Hi Paul
    i too wear glasses and have not been able to get along with the headband type of magnifiers. A solution I am trying out is to use a magnifier on my Ipad. I got a flexible holder on ebay for about £15 and so far it works ok. It does take a little getting used to since you are working under the camera which is in the corner rather than under the middle of the screen. Here is the link to what I postedon 'latest aquisitions" https://www.scale-models.co.uk/threa....34259/page-50
    Peter
    • Gary MacKenzie
      SMF Supporter
      • 1059
      • Gary
      • Forres , Moray , Scotland
      I bought these @ https://www.amazon.co.uk/gp/product/B0015IN8J6/
      But they are way too expensive now , i paid £47.38
      I think a few others bought these @ https://www.amazon.co.uk/Headband-Ma.../dp/B01MG7IT6I
      • PaulTRose
        • Jun 2013
        • 7075
        • Tattooine
        i got some cheap ones....argos as i remember...............i wear them with glasses and have no problems what so ever, works a treat
        Per Ardua
        • KarlW
          • Jul 2020
          • 1522
          I used an optivisor from time to time, but now I'm wearing glasses the focal point is so close to my face it's silly, maybe a bit of perserverance is needed to get used to it.
            I have some headband ones, like these.
            I find them fine over my reading glasses, although I have taken to copying a couple of the guys on TV's Repair Shop, and just wear two pairs of glasses! My prescription readers with some cheap poundshop ones over the top, in various strengths.
            • adt70hk
              • Sep 2019
              • 10540
              Hi Paul
              I've been using glasses and an optivisor without issue for a few years now and have varifocal lenses.
              Good luck with your hunt.
              ATB
              • SimonT
                • 2824
                I use a genuine Optivisor
                Fits over my varifocals with no problem - couldn't manage without it these days
                Started with a £15 cheapo with plastic lenses - it was rubbish. The lenses distorted the view something rotten and the colour rendering was hopeless. Paint colours looked nothing like they should
                The Optiviser has proper optical ground glass lenses so no distortion and accurate colour rendering - what you look at through the lenses looks the same as without, just bigger of course
                  • 19103
                  Agreed ref the optivisor. If you wear one it has to do more than just make things bigger......
                    I know what you mean about the distortion. I find myself moving the item and my head around a lot to get different parts of it in focus, and always have to do a final check with the naked eye to make sure things are straight. I just thought all magnifiers were like that.
                    I have it less with the double glazing but it still isn't great.
                    What power do most of you go for with the optivisor? I'm thinking 2.5 as that's the best balance on my cheap ones. I know it's yet more money to shell out but I've got more chance of doing a half decent job if I can actually see what I'm doing :nerd:
                    • SimonT
                      • 2824
                      Andy - DA5 2.5
                      They do seem expensive in a single hit at around the £50 mark but I must have had mine for around ten years now
                      • KarlW
                        • Jul 2020
                        • 1522
                        I was always warned off cheaper versions with plastic lenses because of distortion, and all the plastic melting stuff we have in hand.
                          Cheers Simon
                            • 19103
                            Also agreed ref 2.5, that’s what I’ve got as well.
                            • adt70hk
                              • Sep 2019
                              • 10540
                              Hi Paul
                              I currently use one of the cheaper plastic versions with multiple lenses, 4 my case, because I couldn't afford anything better at the time and had only just rejoined the hobby and so I didn't want to splash out on something expensive. In my case they seem to work fine.
                              In my case I wear varifocals too as I'm badly long sighted. my standard lens is a 1.8 magnification. Although I fully realise that may not be an exact match because the lenses are plastic.
                              Hope that helps.
                              ATB
