Decals - after care?
    Hello
    Can I please soumd you out regarding decals? Having just finished applying a whole host of decals to my Sopwith Pup, using Revell Decal Softener, it crossed my mind, as it always does, as to whether or not I should be applying a coat of anything on top of the finished model. I have already applied flat varnish to the whole assembly before applying the decals but, of course, the decals are vulnerable.
    Any advice is, as always, appreciated.
    Kind regards
    Aidan
  • AlanG
    • 6296
    After applying decals i always seal them in with a coat of 'varnish' which in my case is Klear
    • yak face
      • Jun 2009
      • 14233
      • Tony
      Hi aidan , most people usually give the model a coat of gloss before applying decals (the smooth surface helps avoid the silvering effect caused by tiny bubbles getting trapped in the rough surface of a matt paint finish) , then when the decals are fully dry a final coat of matt, or whatever finish is required , seals the decals in. Are you going to get us a few pics of the pup? cheers tony
        Many thanks to everyone for their input which is much appreciated. If the work is up to scratch on completion, I shall post some pics.
        Kind regards
        Aidan
