Partisan ambush
    Hi Jason.
    I think it's meant to be a pine, so your looking at greys through to rusty reds.
      Originally posted by Jason Crausby
      [ATTACH=CONFIG]n1141501[/ATTACH]
      I took this pic the other day... I might struggle with this as your perception is that tree bark is brown but here the tree is mainly green!
      Jason . Yes it would be , this must be on the wettest side of the tree. Also not in open land so in a damp spot .Here's a few others
      All depends on what the tree is.
      • Jason Crausby
        • 658
        #18
        Thanks all... just been for a rather damp stroll and came up with these which are closest to the bark on the model...Click image for larger version
        lots of green a red browns in there, plus much darker where it is wet near the base...The
        Figure is finished now so I will start with the tree and crack on from there.
        Thanks
        Jason
        • Jason Crausby
          • 658
          #19
          My attempt at the broken tree...
          • wotan
            • May 2018
            • 1187
            #20
            Jason
            That looks a lot like a tree! Very well done sir
              • 19103
              That is great Jason. It looks like you are holding a real tree......
                Brilliant!
                • adt70hk
                  • Sep 2019
                  • 10540
                  #23
                  Very, very good tree!
                  ATB.
                  • Jason Crausby
                    • 658
                    #24
                    Thanks all... not much done today (home schooling!!!).... need to add more leaves especially round the base of the tree and just prepping to add a small stream.... nearly done!
                    Thanks
                    Jason
                    • Jason Crausby
                      • 658
                      #25
                      Base is about done... just added an oil was a few more leaves and water effects...Click image for larger version
                      Just trying out creating a few discarded shells from the MP40 by snipping some painted wire.... I hopefully want one splashing into the water but that may or may not come off.???
                      Jason
                        • 16157
                        Hi Jason
                        Great tree and base. For a single figure vignette you have managed to get in a lot of fine detail and interest.
                          • 19103
                          Great, these little additions really bring it to life.......along with the great base this is going to be a stonker.
                          • Jason Crausby
                            • 658
                            #28
                            Thanks Jim....the shell cases aren’t really too visible... but I’m now calling this done!
                            Not sure if the water effects have worked out either?
                            Thought I’d take advantage of the frosty weather to get some outdoor shots.
                            This is a lovely simple kit and I’ve really enjoyed doing it...
                            Thanks for looking in!
                            Jason
                              • 19103
                              Love this. Great attention to detail and composition. There is more than a hint of Violet Szabo about her. Carve her name with pride!
                              • Jason Crausby
                                • 658
                                #30
                                Thanks Tim... sorry our earlier posts crossed!
                                Jason.
